  #1
Old 01-23-2007
deckhanddave's Avatar
deckhanddave is on a distinguished road
leak-proof keel stepped mast idea
I just finished reading the thread about keel vs. deck stepped masts and started thinking about my own keel stepped setup. The one big drawback I see is the water intrusion into the cabin through the halyard holes. So here's my idea, what if you plugged the mast with a piece of foam or other material at the deck level and then drilled a small hole through the mast lavel with the foam. I don't like the idea of drilling holes in my mast but when you consider the size holes people drill to get internal halyards, one or two 5/8 holes doesn't seem too big at all. (I know, I know, yet another crazy one from the young newbie)
  #2
Old 01-23-2007
Forget it...doesn't work. Will allways leak. Thru sail slot, between deck collar....
Install mast in front head shower like I did. Still leaks but I don't care.
  #3
Old 01-23-2007
Also, if the foam absorbs any water...which it will, it will promote corrosion at the one place you really don't want it...the point where the mast is stressed by the deck. Good plan for spar failure if you do it that way.
The only real way to do it is to have only external halyards, and to have the mast be without unsealed holes... but that is both unrealistic and almost impossible...not to mention inconvenient as hell.
  #4
Old 01-23-2007
In one word....FORGET IT
  #5
Old 01-23-2007
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Leakage on mine is pretty minimal. Halyards are external and step is the head like G- so doesn't matter if it does leak.
Maxum 3200 Miss Adventure
Formerly - Tartan 34C Yawl
  #6
Old 01-24-2007
my mast is almost in the head but regardless, its right on the bilge. Right after I posted that question I started thinking about aluminum corrosion, if I'd thought about it earlier, I wouldn't have even posted. The idea has been officially forgotten.
  #7
Old 01-24-2007
catamount's Avatar
catamount is on a distinguished road
Wait, don't give up yet!!
In Richard Henderson's book, "Understanding Rigs and Rigging," he shows a diagram of something similar:
1. a balloon to fill the mast and block it off
2. poured closed-cell foam on top of the balloon to level it off
3. poured epoxy over the top of the foam.
The foam and epoxy are done with the boat healed so that the top surface is sloped to promote drainage, and this is done at the level of the lowest halyard exit, so no need to drill extra holes. Make sure that the conduit for you wiring extends well above the block.
I have not done this (yet) myself, so I can't comment on how well it works.
  #8
Old 01-24-2007
That will not work either...
look I have been looking at this problem for over 25 years now, ok??
Unless I am really stupid, which may be the case...THERE IS NO SOLUTION THAT WORKS...IT WOULD HAVE BEEN INVENTED LONG TIME AGO....water will still find its way on the outside and the mast foot cover leak by...
If you do it just bellow halyard exit....most boats have all electric pass well bellow that.....
And Martha Stewart type fixes only work for a week...but go ahead..do it
forget it....
  #9
Old 01-24-2007
Loewe is on a distinguished road
Another reason I have always been a fan of external halyards
Regards,
Red
  #10
Old 01-24-2007
Even with externals it leaks....and those aren't practical at all.
As an example, my mast is 63' tall I have double halyards...just imagine.....
Leaking keel steps are like the rain...we can't avoid it, get an umbrella!!!
You may post attachments
You may edit your posts
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Mast types...? Through deck on deck...? marinesniper General Discussion (sailing related) 41 02-02-2007 09:15 AM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
SEO by vBSEO 3.6.1
