My wing sail design is more easily reefed or furled than a marconi sail, because each batten set is a reef point, and the sail has
lazy jacks. I have made no provision for light air sails, because since it is easily reefed, I gave the boat a large working sail area. You could fly a free standing sail like a
spinnaker (or on a tandem rigged catamaran, a square sail with no yard needed.) I wouldn't flog the boat with extra sail, though - I'd take down any light air sails early.
The
rig needen't weigh very much, if you use carbon / vinylester or carbon /
epoxy for the battens. The masts are engineered for a catamaran, which does not heel. For 1200 sq. feet of sail per mast, they weigh about 1100 pounds each. I wouldn't put it on a tender boat. It is worth noting that the center of the weights is lower than a marconi sail, and that the aspect ratio is about 2 : 1.
You could have variable camber, if you wanted to. I don't intend to have variable camber on the boat I am building. The sail
hinge could incorporate stops which were adjustable, which would have to be adjusted with the sail furled. With some additional complexity and a bit of extra weight, you could
rig high-test small diameter
lines which acted as stops, which could be led to the bottom batten inside the sail, where they could be adjusted while underway.
