Fuel Consumption - SailNet Community
post #1 of 11 Old 02-12-2007 Thread Starter
Wish I never found SN!
SimonV's Avatar
Fuel Consumption
what would be the expected fuel consumption, for a PERKINS 4-180 50hp in a cal 39. only has @ 50 Us Gallon tank. (cruising, not flat out)
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #2 of 11 Old 02-12-2007
A little less cheek
ianhlnd's Avatar
There's a formula for this which I've long forgotten. Maybe Cam will know. My 65 hp ford-lehman pushing 37 ton displacement at 65% power averages 1/3 gal per hr at 5 kts.
ianhlnd is offline
post #3 of 11 Old 02-12-2007
Location: Ft. Lauderdale, FL currently CLODs [cruisers living on dirt]
my 4.236[82 HP] avgs between 1.25 and 1.5 gal/hr. The best solution is to measure your own burn. Fill it up. Write down the hours on the engine, cruise for a bit, fill it up again, look at the hour meter, calculate your real burn.
Jon D
SV Sirius
Moody 47
svsirius is offline
post #4 of 11 Old 02-12-2007
I want your engine !! That's less fuel burn than my generator which is about a liter/hr and it's a 1 cyl 12hp engine...
Jon D
SV Sirius
Moody 47
svsirius is offline
post #5 of 11 Old 02-12-2007
Larus Marinus
Idiens's Avatar
My very ancient Volvo MD21A 56 hp sucks 3.5 litres and hour at 2000 rpm. So I guess about 1 US gallon an hour. (6 knots, 7000kg, 38 feet).
Idiens is offline
post #6 of 11 Old 02-12-2007
Very rough calculation (many many unknowns)
Fuel usage 1 gal/hr (+- 50%)
Speed 6kts (-1, +.5)
Range with 50 gals. 300 mi. ( The error estimate is left as an exercise for the reader)
That much power (50hp) could probably get a bit more that 6.5 knots, but it would be at the expense of really significantly more fuel consumption.
gc1111 is offline
post #7 of 11 Old 02-12-2007
Pamlicotraveler's Avatar
It can vary tremendously based on RPM. Our Yanmar 4hj will more than double consumption between 1500 and 3000 RPMs
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #8 of 11 Old 02-12-2007
pigslo's Avatar
My 4-108 at under 2000 rpms... about a gallon an hour 6.5 mph. Push over that and at 2500 rpms you can almost double that 8mph (Hull Speed). Boat, 17000 lb 36 ft lod, 32 ft lwl.
pigslo
pigslo is offline
post #9 of 11 Old 02-12-2007
Valiente's Avatar
Very hard to answer as it's based on LWL, hull shape, prop efficiency and power band. I will say that in my experience it's the last 1.5 knots before top speed that eats up the fuel. If you can push the boat 7 knots in flat seas below, say, 2,800 RPM (too bloody loud for me), you'll probably get best fuel economy at 5.2-5.5 knots and 1900-2150 RPM. Scale up and down as boat, engine and real life require.
Valiente is offline
post #10 of 11 Old 02-14-2007
Pathfinder
I have a 52 HP Pathfinder on my 24,000 lb fiberglass schooner, 33 ft lod + 12.5 ft Bm. It is slightly over-propped with an 18x15 three-blade, which I very much like because it keeps the engine around 1600 RPM, and she burns 0.5 GPH @ 5 to 5.5 knots, but goes up to 0.75 @ 6 knots and 1.0 trying to better that, without much more effect than a bone in her teeth and a wake. At 5 knots she slips through the water with hardly a ripple.
Hawk
Hawkeye25 is offline
fuel consumption Darco1 Gear & Maintenance 1 04-12-2005 01:15 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
