I Just Baught My First Boat!!! - Page 2 - SailNet Community
post #11 of 19 Old 02-23-2007
humble pie rat
CapnHand's Avatar
First of all, congratulations! Nice choice, looks like you picked a good one.
Removal of a deck stepped mast is an opportunity to make new friends and maybe enjoy the company of old ones. Three or four people make it an easy job.
First sails, boom, cunningham, vang, etc are been taken off the mast. Disconnect any wiring. You can do this yourself. Then you bring the boat under the mast hoist at the marina and tie off. Someone experienced is operating the hoist and directing operations. The cable is lowered from the hoist and a sling is put around it. this is then brought up under the spreaders and tensioned just enough to take up the slack in the cable. The mast and standing rigging is disconnected where it attaches to the deck. The rigging is secured to the mast temporarily with a short length of line or tape. The mast is hoisted until it is slear of the deck. It should still be bottom heavy so it won't topple so one person can handle the butt end. Hoist it up to grade level and place it in a cradle. Remove the spreaders, tie up the rigging more securely to the mast and then place it on the mast racks.
If your marina doesn't have mast racks, the mast is stored on the deck of the boat using stands at the bow and stern.
Did I forget to mention anything?
There are 10 kinds of people. Those who understand binary and those who don't.
CapnHand is offline
post #12 of 19 Old 02-23-2007
can't re member
http://www.tacktick.com/2007Tacktick...ts/default.asp
You don't need to do this but... if you really wanted to....
I don't have any experience with them but I always thought they were a cool idea. I would try to find someone with practical experience before dropping loot though.
yotphix is offline
post #13 of 19 Old 02-24-2007
Hitchin' a ride
bestfriend's Avatar
Kacper- I forgot to say congrats, hope all goes well. Nice boat, looks real fine! I have to agree with Cam though. I don't know your sailing experience, so I mean no offense. For a first boat, I would forgo the major electronic upgrades and save the money for the next boat (and there will be a next one!). Windex and learn how to read the water, ripples, foam, etc. You'll be a better sailor for it. Best wishes to you.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
bestfriend is offline
post #14 of 19 Old 02-24-2007 Thread Starter
Kacper's Avatar
Hmm.
Can you guys direct me to a link where I can read up on "reading water" ?
I'm always concerned about the wind speed because I like reefing early, and I thought this would be a good idea to have the wind speed display.
The only other signal for me whether I should reef or not is if the boat begins to heel over excessively on reaching tacks.
I saw those hand held wind speed things... I guess I'll try it out
The full wind speed kit would cost me around $500 - $1100 I realized today
Kacper is offline
post #15 of 19 Old 02-24-2007
Hitchin' a ride
bestfriend's Avatar
try this for starters
http://www.zetnet.co.uk/sigs/weather...aufort.htm#sea
Vaya con Dios
post #16 of 19 Old 02-24-2007
CBinRI's Avatar
Looks like a wise choice. Congratulations.
CBinRI is offline
post #17 of 19 Old 02-24-2007
Wandering Aimlessly
PBzeer's Avatar
I'll have to ditto cam's post. I have a C 27 next to me, and I wouldn't want to tackle that mast by hand.
Good luck on the survey.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #18 of 19 Old 02-24-2007
Unstepping the mast
Kacper
Many of the former government docks in our area have small manual or electric derricks on the ends of the piers - Horseshoe Bay, Squamish for sure do. At low tide there is usually enough clearance to lift a deck stepped mast and lay it on the boat. Most of these docks have been turned over to municipalities or regional districts and there is often a nominal (modest) fee to use the crane.
It's not the weight that's the problem it's the leverage and your inability to control the drop without overhead support. Also without a tabernacle the bottom of the stick will get away from you.
But even with a smallish boat like the C27 you will need a fairly low tide to get this done. You only need to lift a couple of inches, but you need to be able to get your lifting attachment high enough on the mast for good balance (eg under the spreaders). In the past we used the Squamish crane to rig and de rig many different boats, and frequently used the hoist to lift our 2500lb Martin 242 for a pre race clean (even before they put an electric hoist in!)
Faster is offline
post #19 of 19 Old 02-24-2007
Kacper Congrats!
She looks very very nice.
I would say forget the mast head wind speed. Use a hand held if you have too.
"I'm always concerned about the wind speed because I like reefing early, and I thought this would be a good idea to have the wind speed display."
"The only other signal for me whether I should reef or not is if the boat begins to heel over excessively on reaching tacks."
You need to reef when you push hull speed. After a while you will see when the rigging is under strain and then reef/drop the main.
Hope to see you "out there" some day, I am off to the South Pacific.
Dave
s/v Free Spirit
Columbia 28
davidbrooke2003 is offline
You've Bought the Wrong Boat John Kretschmer Buying a Boat Articles 0 06-01-2004 08:00 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
