Old 01-09-2002
walt123 is on a distinguished road
Making hot water
I am removing an old Bosch propane hot water on demand heater. I am looking for an electric substitute. The unit is for the occasional hot shower underway. I have a 2500 watt inverter and plenty of battery storage. I have a 12V pressure water system. Any suggestions?
Old 01-09-2002
mojizm is on a distinguished road
Making hot water
Do you have an inboard engine? If so any of the small marine tank type heaters w/ heat exchangers work with the benifit of converting waste heat into hot water. If you want just an electric heater a small residential unit might work for a couple of years at a smaller cost than the marine models but keep in mind that a 1000W element will draw over 80 amps at 12V. and it will take an hour + or - to heat that tank.
Old 03-09-2002
Peter_pan is on a distinguished road
Making hot water
I think your going up hill with that idea. You just think you have enough battery storage. an electric water heater will kill your batteries in less than half a day. you cant even generate that kind of power without a 3000 watt generator. most water heaters are only 6 gallons. I can''t take a shower hardly with that. Fire is the most effective way to heat water. you''ll be alot happier with a new gas fired water heater. Propane is a lot cheaper than running a generator or engine to make hot water.
Jim
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
MacGregor 26 vs. ? jiml2p Boat Review and Purchase Forum 184 08-30-2011 08:10 PM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
what about water balast ? AbelCasillas1 Boat Review and Purchase Forum 10 08-15-2004 06:07 AM
Water storage while cruising sloopjohn Cruising & Liveaboard Forum 0 12-06-2001 07:48 PM
