Bottom Job - Page 2 - SailNet Community
post #11 of 15 Old 03-10-2007
If you decide to apply a barrier coat, read and follow the directions on the label carefully. The label says that each coat of barrier paint should be applied within a certain period of time after the previous coat, and the first coat of antifouling paint should also be applied within the same period of time. The reason is to make sure they are chemically bonded. If you don't follow that time schedule, you need to apply a primer before the first coat of antifouling. Otherwise, the antifouling might peel off. If you have any doubts, call the Interlux 800 number on the label. They have an excellent tech support line.
I assume you're planning to keep the Cal for awhile, since you're doing that much work on it. If so, I'd suggest you barrier coat it, even if it has no blisters. The hardest work is stripping off the old paint. Once that's done, applying barrier coat isn't a bad job, and it's good long-term insurance against future problems. I just had mine stripped, and will be barrier coating it this spring, as soon as the weather breaks, so I'm following my own advice.
Sailormon6 is offline
post #12 of 15 Old 03-10-2007
ASA and PSIA Instructor
Originally Posted by Mc51
Much Thanks! ....but the sanding seems to be faster. Luckily we're at the end of a dead end street. I don't complain to my neighbor about how loud his Harley is so he can't complain about the sander's noise.
Mc51
If your sander doesn't have a vacuum pickup so you leave no residue, keep an eye out for anyone from the EPA, you would be in big hot water...
sailingfool is offline
post #13 of 15 Old 03-10-2007
T37Chef's Avatar
Nothing to do with noise...
Mc51
It has nothing to do with the noise, rather the dust created from the sanding that contains very harmful products, not to mention when the dust settles and you get the slightest amount of moisture, it will be the color of the paint your sanding. This is also a main reason you MUST use a vacuum attachment when sanding in the boat yard. Not much will piss me off more then when someone does that right after polishing my boat.
Shawn
T37Chef is offline
post #14 of 15 Old 03-10-2007
Tom967's Avatar
I had my boat 7 months on the hard.."One of the perks here in Florida...So I learned and emulated from the very best..The pros and boatbuilders...Getting the old old layers of paint is the dirtiest job in the world..a bit dangerous I might add.."On skin and respitory system" and takes forever...and a pain in the ass for others working on their boats...What would take you two solid weeks can be accomplished in 40 minutes.."Call in the sandblaster"..
Now If you can afford a little time...get a gallon of 2 part marine tex and a putty knife..Fair this compound to your hull..sand it out.."A couple of days ...if you work hard"
Now use Pettit Protect.. follow directions closely...bonds with bottom paint..West marine bottom paint fine..in fact made by Pettit.."By the way the fairing compound will protect against blisters..Now you have ultra first class job.."Actually if you go to my website..www.afewgoodboats.com...I have pictures of these processes...Link #2..The Boatyard..Larry Link...one of the best..old school boatbuilder..
Tom967 is offline
post #15 of 15 Old 03-10-2007
The easiest, least expensive way I've found for a do-it-yourselfer to remove old bottom paint is to use a paint stripper made specifically for use on fiberglass. I get it at a paint supply store that specializes in automobile paints. Don't use ordinary paint strippers, because they're too aggressive, and will damage the gel coat.
Spread a tarp under the boat, and brush the stripper on with a 4" brush. Don't scrape it off. Keep brushing additional coats of stripper on top of the old paint and prior coats of stripper. The objective is to keep it wet. After 3-4 coats of stripper, try to scrape the paint off a small area. When most of the paint comes off an area with fairly easy scraping, then it's ready to be scraped off. If the paint doesn't scrape off fairly easily, then apply more coats of stripper. When you scrape it, just let it drop on the tarp and when you're done, roll up the tarp and throw it away.
After the paint has been remoived, I wipe the area with acetone and then wash it with soapy water, rinsing it thoroughly.
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
Bottom Job / Barrier Coat hamiam Gear & Maintenance 14 04-02-2003 07:40 PM
Bottom Job question(s) rookie00 Gear & Maintenance 19 03-19-2003 03:01 AM
Hull Preparation for Performance Dan Dickison Racing Articles 0 05-09-2002 08:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
