03-20-2007
SVDS-
It's obviously a 12" G4 PB... same beast I use on my boat... the aluminum finish and side-loading optical drive give it away.  My guess is that you're using two strips of 2" wide velcro for that...
What is up with the outboard on the transom? It looks like it is on a bracket so it can be used to motor with... did you remove the inboard or is that so you can use it as backup auxilliary power for the P36??
Just curious as to why so many of your photos seem either fogged or blurry? I guess it's the photo teacher in me that is asking...
