Masthead light height - SailNet Community
post #1 of 27 Old 03-28-2007 Thread Starter
Is there a minimum height requirement for masthead lights. I have a 79 Cheoy Lee ketch (32') and noticed that all the other boats in the marina have their lights quite a bit higher than mine. Just curious. Thanks
David
dsmylie is offline
post #2 of 27 Old 03-28-2007
Seņor Member
TrueBlue's Avatar
The masthead light should be atop the main masthead . . . . Unless you're referring to the light stanchion? I don't think there is a minimum height to this regard.
Otherwise, perhaps the other boats in your marina have higher masts?
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #3 of 27 Old 03-28-2007
No, a masthead light, under the Rules, is NOT a light atop the mainmast. It is a misnomer.
A masthead light is the light in the forward part of the vessel, along the centerline, which shows through an unbroken arc of 225 degrees so as to show light 22.5 degrees abaft the beam on either side of the vessel.
On a sailboat, it is used only when under power or when motorsailing.
To my knowledge, it's height on the mast isn't critical, so long as it's considerably above the sidelights.
Bill
btrayfors is offline
post #4 of 27 Old 03-28-2007
sailortjk1's Avatar
Thought that was the steaming light and the masthead light was the 360 degree anchor light.
Please correct me if I'm wrong.
sailortjk1 is offline
post #5 of 27 Old 03-28-2007
Seņor Member
TrueBlue's Avatar
A masthead light (or anchor light) is on the MASTHEAD! It's required use is when anchoring at night. AFAIK, The height of the stanchion, or staff it's attached to is not regulated.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #6 of 27 Old 03-28-2007
sailortjk1's Avatar
Hence the name Masthead.
post #7 of 27 Old 03-28-2007
Learning the HARD way...
eherlihy's Avatar
Nope,
Per The Annapolis Book of Seamanship
"The masthead (steaming, bow) light, which when lit indicates that the boat is under power, is a white light located not at the top of the mast, as the name suggests, but partway down. (On small power vessels it may be placed at the top of a short vertical spar). On most sailboats it's about a third of the way down from the actual masthead. Showing over the same arc as the sidelights, it is turned on only when the boat is under power. "
The rule that I remember is that it must be "signifigantly" above the sidelights.
At the club that I sail with, the guy that owns the (50+) boats has started to move some of the steaming lights DOWN on the mast, so that he can replace them without having to climb the mast, or get a ladder.
eherlihy is offline
post #8 of 27 Old 03-28-2007
eherlihy's Avatar
Looks like we all jumped on this at the same time....
eherlihy is offline
post #9 of 27 Old 03-28-2007
sailortjk1's Avatar
Well thats just dumb, LOL.
What do they call the 360 degree anchor light on top of the mast than.
The Masthead head light.
Thanks for the clarification.
I'm still going to call them wrong. Steaming or Bow light and Masthead or anchor light makes more sense if you ask me. LOL
What do they (I) know!
post #10 of 27 Old 03-28-2007
Seņor Member
TrueBlue's Avatar
Guess me and tj should have let you and Bill jump first . . .
True Blue . . .
sold the Nauticat
TrueBlue is offline
Orca Green LED Masthead Light capecodphyllis Gear & Maintenance 7 02-02-2007 12:31 AM
Masthead Rig Genny Height dave.verry Gear & Maintenance 10 10-05-2006 11:53 AM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
