  #141
Old 04-14-2007
Valiente's Avatar
Originally Posted by RickBowman
It's a 1997 Pacific Seacraft 32' Pilothouse. Hull #20. There are images uploaded in the Pacific Seacraft forum here on sailnet.
I found all that you posted to be of unusual interest.
I agree with you. The vessel that I originally posted earlier in this thread had been sprayed with foam and it didn't impresss me either.
I will look up the PS 32. I have some photos of other steel boats I looked at and examples of why I didn't like foam.
Here's a French ketch in steel, a 1980 Subrero Petit Prince. Guy wanted $60K and it was at my club. Close to perfect in terms of design:
...but it had not been maintained where it counted, despite the beautiful interior:
I can't remember the make of this one, but it looked fast and the exterior showed fresh paint:
Again, unfortunately, the owner's own pictures told the story of how you need to keep on top of trouble areas. I sometimes wonder if just lining anchor lockers with truck bed liner isn't the best idea:
Here's how my new-to-me boat avoids the problem:
Pardon the inflatable in the way, but it's the best shot I have. There is a forward sloping well in the deck into which the chain is flaked. The well has a drain above the waterline in the stem that means anchoring water never enters the boat. It's visible here, along with the triple rollers on the short, heavy bowsprit:
I have enough buoyancy forward to carry a few hundred pounds of chain easily, plus there's a safety bonus of stepping into a shallow box to work at the bow. The windlass has been bought, but has yet to be installed. It will be bolted to a bracket on the centerline of the well, and as chain is brought aboard, it will have to be manually flaked side to side. This is of course a compromise, but I accept it as it gives the benefit of being able to wash down the chain and inspect it in full daylight, plus I don't get muddy water in the forepeak, plus I can't have a tangle belowdecks...it's all there in front of me. I am thinking of lining this area in the aforementioned truck bed liner or something similar. I may also make a pair of clamshell-type covers just to tidy up that area.
Sorry for the size of this "photo essay", but I am a bit of a boat bore, having been immersed (no pun intended) in the subject for several years. I have seen about six steel cruisers in person, and about 20 via the magic of the Internet. I'm far from an expert, but you learn to look for certain things, and if you find them, you move on!
  #142
Old 04-14-2007
Senior Moment
RickBowman is an unknown quantity at this point
Well done indeed. Thank you for the informative images. I have always prefered the anchor locker drain to exit out and not to the bilge.
The size of the photo essay was great. Like with much, the devil is in the details, and the seams, welds and fillets and the images that you provided showed the corrosion and neglect on the vessels that you have inspected.
Now about your anchor locker liner? Are you thinking about how to stop the chiping of the paint from the chain striking the locker walls? Would you consider lexan attached to the anchor locker walls and bottom?
  #143
Old 04-14-2007
Originally Posted by TrueBlue
Interesting to compare Valiente's sailplan with True Blue . . .
TB and Valiente...want to laugh??
Then compare both of yours sailplan with mine...and also the hull......just for curiosity!!
The first photo was the first drawing sent to me with an idea of how she would look like..made into a jpeg
The second one are the Hull lines..sorry about the quality.
Interesting diofferences, aren't they?
  #144
Old 04-14-2007
Valiente's Avatar
Naturally, and if I was racing to the west of Portugal, I'd have your boat. But I wouldn't take it around Cape Horn or even into the average Pacific lagoon. I'd just knock something off the bottom.
Trust me, there's an excellent compromise between our boats, and it's nothing a couple of million dollars can't buy.
  #145
Old 04-14-2007
me neither..
In fact I wouldn't take her that much far from the coast...like crossing the Atalantic.....
It would be unconfortable...very....I believe...
The compromise between the two boats exists, yes it does...Nautor!!!!
  #146
Old 04-27-2007
gaha_1's Avatar
gaha_1 is on a distinguished road
Thumbs up Great boat
I can't wait for mine to grow up,I have a bayfield 25'
You may post attachments
You may edit your posts
Holy Crap - What Happened waltward General Discussion (sailing related) 8 09-15-2004 07:41 AM
Using a Cow Hitch Eric Watters Seamanship Articles 0 02-06-2002 07:00 PM
SEO by vBSEO 3.6.1
