Special Mooring Challenge - Page 2 - SailNet Community
post #11 of 18 Old 04-11-2007 Thread Starter
Thanks for all the suggestions.
We are at a marina where there is no place to keep a 10' board or a dinghy. The inflatable would work as long as we deflate and bring it home with us.
like2sail is offline
post #12 of 18 Old 04-12-2007
Here .. Pull this
This is a fairly common arrangement in Nova Scotia. I don't remember the mooring buoy having anything on it in the way of blocks, pulley, sheaves or little round thingys that make the ropes go. The buoys they used were big orange rubber ones and the rope just ran through the eye on the end of it. The line has to lie on the bottom, underwater, hence there is no tension on it, no chafe. You still want to inspect it every week or so though. Try it out and let us know if the boat comes loose so we can keep an eye out for it.
Sailormann is offline
post #13 of 18 Old 04-12-2007
paulk's Avatar
We moored our Soling on a "clothesline" setup much as described. The toughest part of the setup was clipping the two ends together (...outside of everything...) when we went off sailing, so we'd only have to pick up one line when we came back. Chafe wasn't much of a problem. An area that has so little traffic that you can get away with such a setup won't be likely to have much in the way of waves either. We used a 1.5" line, just to be sure, and a big (used, and therefore cheap) block. We would leave the boat tied with the stern towards the dock so we could pull her in and step aboard without any gangplank, but you could also have both ends of the line attached at the boat's bow, so she could swing at the mooring if she had to. (You could get some wild twists in the line doing it that way, however.) Worked well for about 8 years, I would guess.
paulk is offline
post #14 of 18 Old 04-12-2007
PaulK-
How'd you get that line over the tiny cleats on a Soling??? Attaching the lines at the bow sounds like a recipe for disaster if the wind and tide have any effect at the mooring.
sailingdog is offline
post #15 of 18 Old 04-12-2007
sailortjk1's Avatar
1.5" Line! ???????
I don't get it?
sailortjk1 is offline
post #16 of 18 Old 04-12-2007
Sailortjk1-
He was using a 1.5" diameter line...which would take about a month to chafe through with a boat the size of a Soling...
post #17 of 18 Old 04-12-2007
Armchair Horn Sailor
Alden68's Avatar
If you are goin to employ a gangway I would strongly recommend a 2x10. A 2x6, unless you work for the circus, would be extremely diffucult to balance on, with a load, out to a pitching boat. In either case, doubling them up is the safest way to travel although weight does become an issue.
Alden68 is offline
post #18 of 18 Old 04-12-2007
Alden-
Ruin all our fun...I was waiting to hear the big "sploosh!" of them falling in...
picking up a mooring single handed jasonr575 Cruising & Liveaboard Forum 16 07-17-2013 10:23 AM
Mediterranean Mooring John Kretschmer Seamanship Articles 0 12-22-2003 08:00 PM
The Mechanics of Mooring Mark Matthews Seamanship Articles 0 05-19-2002 09:00 PM
Surveying the EDS Atlantic Challenge Dan Dickison Racing Articles 0 08-05-2001 09:00 PM
The BT Global Challenge—Halfway Around SailNet Racing Articles 0 03-11-2001 08:00 PM
