04-13-2007
Best Looking MALE Mod
Our 380 had a blue hull (Emrond). Heat is not a issue - in my opinon. Another positive of a Emrond hull is that it is easy to clean and needs no waxing. Things wash right off (except around the T-Hulls like the bilge & A/c which acquires a haze). I do not care much for blue gell coat - it oxidizes and requires maintenance.
Paint it if you can afford it. However, Cam is right about it showing all of your "less-than-perfect" docking manuevers. That is a benefit of having a spouse on board. When someone comments, you can always say, "Yep. That was the time I let her drive..." (comments best made when she is not around)!! HAHA!
IF you have not priced it, the cost runs somewhere between $175-$225/ft for Emrond. Not a cheap option... but MAN IT LOOKS GOOD and will set you off from all the other boats. I remember coming into an anchorage one time and one of the floating-mobile-home residents screamed out, "You get a pair of roller-blades with that!??" (like I was a yuppi... well, which may not be too far from the truth). I flipped him off and laughed. It was not as if his boat had a motor anyways.
THere is a positive and negative of having a beautiful, gorgeous boat with a painted hull. The positive is that you will stick out in EVERY anchorage and you look awesome. The negative is the same: You will stick out in EVERY anchorage, for those who admire your boat for reasons other that pure admiration. That is the only thing that is preventing me from painting our 400 (which I probably will anyways). I am concerned about sticking out in the south islands as the Rich Gringo!!! Keep that in the back of your mind...
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Follow me on Facebook:
