Bridle for Buoy Mooring - Page 2 - SailNet Community
post #11 of 22 Old 04-25-2007
I kept my boat on a mooring buoy for years. Best place for it. I suggest you use chain, shackled and moused. You can put a loop in the other end using a shackle and cover the loop in plastic tubing to save your decks. run the chain over the roller and put the pin in to stop it jumping out. If you want to double up with rope, use 3 strand nylon with a thimble and shackle to the buoy and lots of anti-chafe. I prefer a plain end just cleated in the normal way, as it can be released under load. Once you 'get to know' your buoy, you can judge if you need rope for shock absorption - chances are, in deep water, there will be plenty of play in it's own chain. I would say that the last picture in Halekai 36's post shows the pendant far too long, she will sail all around it in a blow.
Another couple of tips: regularly scrub the buoy, as at times it will be pulled hard alongside and you don't want barnacles etc scratching your gelcoat. If it is the type with a metal ring on top, cut an old (small) fender in half, cut a hole in the end and thread your pendant through the hole. Then use the fender to cover the ring - can save a lot of damage. Don't forget one of the easiest ways to pick up a mooring buoy is to lasso it with a loop of (non floating!) rope, pull yourself up to the buoy and make fast at your leisure. Also, by walking the buoy alongside you can leave under sail in just about any direction. No worry with springs, fenders, tricky docking maneuvers etc. It's the way to go.
burlesque is offline
post #12 of 22 Old 04-25-2007
If you're going to use chain to attach your boat to the mooring ball, you best have a very good, sturdy, and well secured mooring bitt. Otherwise, the shock loading that can occur can rip the chain off the boat. While nylon lines have the risk of chafing through, they do absorb a lot of the shockloading.
sailingdog is offline
post #13 of 22 Old 04-25-2007
hard to see that in your post although the eyes did not look loose in between the binding. just should have clarified at the start.
mike dryver is offline
post #14 of 22 Old 04-25-2007
Kept my boat on a mooring buoy for years - best place, no springs and fenders or tricky docking maneuvers. I used chain, shackled and moused to the buoy, with a plastic covered loop in the other end made with a shackle. My second line was 3 strand nylon with a thimble, shackled to the buoy. Lots of anti-chafe. I prefer a plain end, cleated in the normal way as it can be released under load. The chain should be led over the bow roller with the pin inserted to stop it jumping out. I believe the last picture in halekai36's post shows the pendant far too long: she must sail around all over the place in a blow. Depending on how the buoy is attached to the bottom and the depth of water, there is likely to be enough play in the system to obviate the need for shock absorption.
A couple of tips: scrub the buoy regularly as,at times, it will lie hard alongside and you don't want barnacles etc. scratching your gelcoat. Also, if it is the type with a ring on the top, get an old fender, cut it in half and cut a hole in the end. Thread the pendant through the hole and use the fender to cover the ring - can save a lot of damage.
If you are not used to a mooring buoy, remember one of the easiest ways to pick it up (can be accomplished by granny or from the cockpit) is to lasso it with a loop of (non floating) line, haul yourself in and make fast at your leisure. Also, by walking the buoy alongside, you can leave under sail in almost any direction. Who needs a slip?
post #15 of 22 Old 09-02-2008
1987 Pearson 27
Joel73's Avatar
Quick question about pennant size... i've searched for another guide but must be typing in the wrong keywords.
Our boat displaces almost 6000 lbs... what diameter line should i be using for the pennants? I made a mistake and ordered 1" line based on some online quick guide and wow was that overkill!!!
So what size? 1/2" 15' OR 3/4" 15"?????
Thanks!
"Unthinking respect for authority is the greatest enemy of truth." - Albert Einstein
Joel73 is offline
post #16 of 22 Old 09-03-2008
Joel-
I'd go with a 5/8" mooring pennant... I think 3/4" is a bit overkill and 1/2" too light.
post #17 of 22 Old 09-03-2008
1987 Pearson 27
Joel73's Avatar
Thanks SD... i thought that was going to be the answer.
Joel73 is offline
post #18 of 22 Old 09-03-2008
My thoughts on mooring pedant lines is that they should be close to the size of the anchor rode you're generally using... unless you're using an unusually light anchor rode. I've seen 15000 lb., 31' power boats anchored out on 1/2" line and think that they're idiots... but that's just me. I'd imagine they use the same 1/2" lines to tie up to a mooring ball.
BTW, if I'm tying up to a mooring for a short period of time, I will often use a lighter line...like a 1/2" dockline...but if I'm going to be leaving the boat on the mooring, I'll dig out the 5/8" stuff.
post #19 of 22 Old 09-03-2008
1987 Pearson 27
Joel73's Avatar
I decided to go with 3/4"... and here's why: I talked to my neighbor whose mooring we used on occasion until we got ours installed. He said he had 3/4" which worked great for our chocks and cleats... so since i've used 3/4" before (unknowingly) then i know it will work for us. I figured a heavier line can't hurt and the mooring is used for storms only so heavier is better. He said 5/8" would be fine too but he preferred 3/4".
Man... when i got that 1" pennant in the mail i thought i was ready to moor a ferry with that sucker!
I'm returning it for this instead: Double Braid Mooring Pennant
Joel73 is offline
post #20 of 22 Old 09-03-2008
Maine Sail's Avatar
Joel,
The same thing is cheaper at Hamilton Marine
3/4 X 15 pendant
I really do feel the Yale Polydyne pendants with stainless thimble are well worth it though!
I replace every two, regardless, but I'm overly anal, and the one I just took off could probably go another three at least! There is NO wear on the thimble and NO corrosion between the galvanized shackle and stainless. Galvy thimbles wear out well before the pendant will.
3/4 X 16 Yale Polydyne
______
-Maine Sail / CS-36T
Maine Sail is offline
picking up a mooring single handed jasonr575 Cruising & Liveaboard Forum 16 07-17-2013 10:23 AM
Special Mooring Challenge like2sail General Discussion (sailing related) 17 04-12-2007 10:51 AM
Mediterranean Mooring John Kretschmer Seamanship Articles 0 12-22-2003 08:00 PM
The Mechanics of Mooring Mark Matthews Seamanship Articles 0 05-19-2002 09:00 PM
Mooring RobGallagher General Discussion (sailing related) 4 03-02-2002 05:59 AM
