cat sail trim - SailNet Community
post #1 of 4 Old 05-07-2007 Thread Starter
cat sail trim
what are some of the basics for sail trim on a cat. i have been sailing a 42 cat for a few months now, but it seems like i should get more out of it. so, for example close hauled: do i want the boom centered up like a mono hull? and then slid it along the traveler as i fall off or what?
dwa1 is offline
post #2 of 4 Old 05-07-2007
dwa1—
It would help is you said which 42' Cat you have... different designs have different problems..
sailingdog is offline
post #3 of 4 Old 05-08-2007
CatSailor from Oz
Send a message via Skype™ to alanl
You will find there is a fairly significant adjustment needed if you have previously been used to a monohull. In particular, you will use the traveller a lot more, especially when close hauled, to power up the main. I frequently have the traveller half way across to the lee side to get most power. Contrary to most reports from multihull sailors, close hauled is actually faster than reaching.
The headsail is also critical. I got a new sails late last year and realised for the first time how well the boat went with the right balance between the head and the main. The boat will round up if the headsail is not pulling well.
My suggestion is to find a highly experienced sailmaker specialising in Cats and get him to sail the boat with you. You may find that just minor adjustments will make a huge difference.
alanl is offline
post #4 of 4 Old 05-08-2007 Thread Starter
great i will try that. and to answer sailing dog, its a 42 kurt hughs cruising cat.
thanks
dwa1 is offline
Sail Repairs at Sea Brian Hancock Gear and Maintenance Articles 0 09-22-2003 09:00 PM
Synchronized Sail Trim Carol Cronin Racing Articles 0 03-16-2002 08:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 09:00 PM
Sail Trim Steve Colgate Seamanship Articles 0 05-10-2000 09:00 PM
Sail Trim Steve Colgate Gear and Maintenance Articles 0 05-10-2000 09:00 PM
