What makes your boat cozy? - SailNet Community
post #1 of 58 Old 05-09-2007 Thread Starter
patrickbwells's Avatar
Smile What makes your boat cozy?
Hi. I just bought a 30 year old Cascade 36' that I am restoring. Ive gutted everything but the v-birth and head and am getting ready to start rebuilding. I have noticed that many boats are just not as comfortable as a home on the land and I want to know what kinds of things Sailnetters have done on there boats to make them comfortable and homey. To start I am going to put in a marine wood stove, probably the 'little sardine'. I am also going to use 3/4 inch plywood for all of the construction so that it feels solid. I have a dehumidifier for use when the boat is connected to shore power. Can anyone tell me what type of 12 volt lighting is the best? Where should I go from here?
patrickbwells is offline
post #2 of 58 Old 05-09-2007
Helms ALee!
tenuki's Avatar
Don't ask me I'm used to racers, so I'm not comfortable unless the interior is gutted.
tenuki is offline
post #3 of 58 Old 05-09-2007
66luders's Avatar
LED lighting. Well.... not really. I put red, white, blue and amber in the v-berth for my daughter.
66luders is offline
post #4 of 58 Old 05-09-2007
theartfuldodger's Avatar
Send a message via Skype™ to theartfuldodger
I refitted our boat which we now live on, and LED is what I installed, even for
Artful Dodger
theartfuldodger is offline
post #5 of 58 Old 05-09-2007
The two problems you can have with LED lighting are:
1) the white is pretty bluish, and not very warm or pleasant in color. Newer LED bundles handle this in a few different ways, so this is going away as a problem.
2) LED lights tend to be very directional. If you need a lot of light over a wide area, you're probably better off with cold fluorescent tube lights.
sailingdog is offline
post #6 of 58 Old 05-09-2007
Armchair Horn Sailor
Alden68's Avatar
I would second the lighting however, there is nothing more cozy than a well done softly lit sailboat cabin......especially if your 1/2 way through the bottle already......
Alden68 is offline
post #7 of 58 Old 05-09-2007
Wood. Lots of warm, cozy wood. Thick seat cushions and soft places to lean while reading or relaxing. Avoid as much as is physically possible in the way of visual obstructions or head banging protrubences. Carpet feels good on the feet but attracts sand and fleas (if you have a pet) so small throw rugs help, but they MUST have sticky rubber backing or they become skateboards at the speed of light. And clean them often. Replace them a lot, too, for fun and a different look.
Insulate well beneath the deck and cabinroof. I have laminated in thin wood and rigid foam insulation. I also like thin rigid foam on the hull down to the waterline, or cabin sole. This makes the boat MUCH better at holding cool air in the summer and warm air in the winter. Exposed fiberglass areas create air circulation that is sometimes so active it feels like a draft from outside.
And one other thing - before you go about doint the interior, check all chainplates, cleats, etc, etc deck hardware and fills and on and on, and rebed/reseal EVERYTHING you possible can. 30 year old sealer was not as good as todays, and even if some of it was, it's 30 years old - retire it, and don't end up with leaks ruining your new interior.
Hawk
Hawkeye25 is offline
post #8 of 58 Old 05-09-2007
Freesail99's Avatar
If you want some nice LED lighting, look here.
As far as making your boat comfortable and homey, I rebuilt my entire galley. I used 3/4 hardwood plywood to make my cabinets. I have 11 lineal feet of counter tops now. I was also able to free up some extra storage space by adding a extra door. I also re did all my cushions. Used better foam. On my bulkhead walls leading to the V berth, I covered the walls with "Bellawood" 3/8 x 3 solid prefinished real wood flooring. I used Mahoagany because my boat has a lot of that wood already in it. Teak is available and the wood it's self isn't very heavy, so I added very little extra weight to the boat with a finish, I would never be able to achieve.
S/V Scheherazade
Freesail99 is offline
post #9 of 58 Old 05-09-2007
Here .. Pull this
I always put a couple of old-fashioned oil lamps in my boats - regardless of whether I need them or not. When you are just sitting and chatting with some folks over a beer they give the cabin a nice, warm glow.
Sailormann is offline
post #10 of 58 Old 05-09-2007
Freesail-
The Alpenglow lights are all cold fluorescent, except for the red nav table lighting which is LED. They don't make any white LED-based lights at that company.
Trailering? Pick a Boat Bruce Caldwell Cruising Articles 0 07-22-2004 09:00 PM
Fine-Tuning the Autopilot—Part One Dan Neri Cruising Articles 0 09-03-2003 09:00 PM
Preparing Your Boat for Winter Bruce Caldwell Gear and Maintenance Articles 0 11-03-2002 08:00 PM
Two-Boat Tuning Dean Brenner Racing Articles 0 03-13-2002 08:00 PM
The New Racing Rules Dobbs Davis Racing Articles 0 04-04-2001 09:00 PM
