Has this boat sank? - Page 2 - SailNet Community
post #11 of 16 Old 06-11-2007
On Blocks
Bermuda30's Avatar
No paper products in an otherwise clean boat may be an indication.
Bermuda30 is offline
post #12 of 16 Old 06-11-2007
Wish I never found SN!
SimonV's Avatar
scuba tank scrapes on the roof lining.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #13 of 16 Old 06-11-2007
SimonV's Avatar
ping pong balls in the vents with mythbusters printed on them.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
SimonV is offline
post #14 of 16 Old 06-11-2007
Looking inside lockers, behind hull liners, and such will often tell you if the boat has seen more than its fair share of water. Signs, like an all new interior are usually fairly suspect in a boat for sale.
sailingdog is offline
post #15 of 16 Old 06-11-2007
Originally Posted by poopdeckpappy
dead fish in the storage lockers ????
Live fish could also be a clue
Quickstep192 is offline
post #16 of 16 Old 06-11-2007
On the more serious note, there will also usually be a water line stain in any woodworking, and green corrosion on any wiring below that level (see especially behind counters and panels) and similar rust stains on screw heads or engine parts, again below that level.
Look under/behind/beyond the obvious to find things like this.
hellosailor is offline
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 07:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
