What is a self furling jib? - SailNet Community
post #1 of 7 Old 06-20-2007 Thread Starter
I have just recently got in to the sport and bought a Catalina Capre 14.2 and am still learning. I was wondering what a self-furling jib is and how to use it. If anyone has some imformation I'd be glad too hear it.
sailingnewby is offline
post #2 of 7 Old 06-20-2007
RickLaPaz's Avatar
It's a system designed to furl the jib.
At least by design anyways........
RickLaPaz is offline
post #3 of 7 Old 06-21-2007
Here .. Pull this
o thnk that this might refer to a roller furling mechanism on the jib forestay. If there is a round drum of some kind just above the deck, and a line coming out of a hole in it - then you have a roller or self-furling jib.
It is a device that lets you roll the jib up around the forestay when you are not using it to sail. if you pull on the line that comes out of the drum, then the sail should roll up around the forestay. If you pull on one of the jib sheets (the lines that are attached to the jib at the bottom) then the sail should unroll...
Check out the following website for more information and owner's forum...
Good luck and enjoy !
Catalina Capri-14.2 specs, photos, and reviews
Sailormann is offline
post #4 of 7 Old 06-21-2007
I've heard of roller-furling jibs, but not self-furling jibs... I've also heard of self-tacking jibs.
A self-tacking jib is a jib that is setup so that you only have one sheet lead to it, often it is on a boom or has a small traveler mounted across the foredeck. This allows the jib to "self-tack" when you tack the boat, meaning that you don't have to free the windward jib sheet and take up the leeward one.
sailingdog is offline
post #5 of 7 Old 06-22-2007
A self-furling jib is a jib that's only furling itself. It thinks it's going somewhere, it has big dreams and struts around bragging, but it's only furling itself, and no one else.
Or not. I could be wrong.
Hawkeye25 is offline
post #6 of 7 Old 06-25-2007
timangiel's Avatar
Talking
My jib has been known to unfurl itself, but has never been self furling
timangiel is offline
post #7 of 7 Old 06-25-2007
humble pie rat
CapnHand's Avatar
Some are self distructructing.
CapnHand is offline
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 08:00 PM
Jib Furling Systems - Results robrichtx Gear & Maintenance 0 12-15-2001 10:21 AM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Seamanship Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Gear and Maintenance Articles 0 05-10-2000 08:00 PM
