Main Sail Reefing? - Page 2 - SailNet Community
post #11 of 29 Old 07-03-2007
poopdeckpappy's Avatar
Nicely done Giu and Columbia, my 26 footer is rigged the same and reefed as drawn by Giu
nice to see a topic like this for a change
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #12 of 29 Old 07-03-2007
BarryL's Avatar
Document with pictures
A few years ago I wrote a short document with lots of pictures that showed how single line reefing was done on my 1986 Newport 28.
I would be happy to send a copy if anyone wants one.
If there is a web site to post I will do that to.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #13 of 29 Old 07-03-2007
Point A is a reef tack, Point D is the reef clew, and points in-between are reef points, which are mainly used to bundle up the sail so the bunt of the sail doesn't blow around or chafe.
The reef tack is usually attached to a tack hook on the goose neck of the boom. The reef clew is setup as per Giu's diagram.
On some boats, they have a set of blocks and a single line that runs from the boom, up to the reef clew, down to the end of the boom—so the line can pull the reef clew out and down at the same time—to a cheek block near the goose neck and up through the reef tack and then down to a block and back to the cockpit. This is a called single line reefing setup—because it uses a single line to reef the sail.
On some boats, they have a set of blocks and a line that runs from the boom, up to the reef clew, down to the end of the boom—so the line can pull the reef clew out and down at the same time—to a cheek block near the goose neck and then down to a block on the deck and back to the cockpit. They also have a second line that goes from the goose neck, up to the reef tack and down to a block on the deck and back to the cockpit. This is a called double line reefing setup—because it uses a two lines to reef the sail.
IMHO, if you want to be able to reef from the cockpit, this is a better setup than the single-line reefing systems.
sailingdog is offline
post #14 of 29 Old 07-03-2007
Valiente's Avatar
Originally Posted by sailhog
Giu's got it exactly.
I can attest that Alex actually can sail properly. He knows when to use the crew to put in a reef line by walking on the boom and when to use Canadians as fenders when docking a 4 metre beam boat in a 4.01 metre slip.
Valiente is offline
post #15 of 29 Old 07-03-2007
saurav16's Avatar
Send a message via AIM to saurav16
What speed winds should a catalina 27 be reefing at i mean with gust speed included?
saurav16 is offline
post #16 of 29 Old 07-03-2007
I'd rather be sailing
labatt's Avatar
Saurav - The general rule of thumb is that if you think you need to reef, reef. There's no fast rule as to the wind speed needed to reef. Reef early, reef often, and practice it. On our Passport 40, we put a mainsail reef in at 15, a genny reef in at 18 or so, a second main reef in at 22 and a second genny reef in at 25. On the other hand, a couple of days ago we were in no hurry and had a double reefed main and single reefed genny at 18-20. We sailed slow, but we sure were comfortable! We don't like being hard over if we don't have to be. It makes our sandwiches fall off the cockpit table. And our daughter gets fairly terrified if we're hard over... The worst thing to do is look around, see nobody else reefed, and feel obligated to leave all your sail out. It's all about your comfort factor and how much stuff you didn't secure in your cabin.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #17 of 29 Old 07-04-2007
Owner, Green Bay Packers
Well done, Giu.
I would note that all of the gear, mentioned by the Dog, is capable of being retro-fitted to virtually any boat. Harken offers two different size kits, in both single line and double line reefing, depending on the size of boat. They can be installed with a modicum of mechanical ability and a few tools. The most challenging aspect of their installation, aside from the cost, is the reinforcing of the mains'l and attaching of a steel ring to it. Perhaps, if in doubt, a sailmaker should perform that portion of the work.
And, for the record, it is a sheave and not a pulley or pully. The sheaves in this case will reside in cheek blocks, tail blocks, and perhaps a floating block. Pulleys are generally found in Erector sets or attached to the limb of an Oak tree for automobile engine removals, both lubberly pursuits. (g)
Wm. F. Buckley, Jr.
sailaway21 is offline
post #18 of 29 Old 07-04-2007
Originally Posted by sailaway21
Well done, Giu.
Most sails that are for larger boats come with reefing points installed.
Well said, in your snobbiest yatchly voice I might add... and you forgot foot blocks.
post #19 of 29 Old 07-04-2007
It seems usage kinda wanders around a bit. Strictly speaking, a sheave is just a grooved wheel. Can't to much with that 'cept roll it around on the floor . A block can refer to either the frame w/in which a sheave is mounted, or the entire assembly. Similarly: Pulley can refer to just the grooved wheel (sheave), or the entire assembly.
Interestingly enough: Of the the three books on sailing I currently have on loan from the library, each of them refer to the assemby as a "block" (most commonly) or "pulley," with only one mentioning "sheave," in passing.
So there you go.
Jim
SEMIJim is offline
post #20 of 29 Old 07-04-2007
Valiente,
What's this about the Portugese "walking on the boom"?
sailhog is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Considering a New Mainsail Brian Hancock Cruising Articles 0 04-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 07:00 PM
Using Riding Sails John Kretschmer Gear and Maintenance Articles 0 02-26-2002 07:00 PM
