Hull Speed - Page 3 - SailNet Community
post #21 of 36 Old 07-04-2007
The CCA boats have long overhangs. So as the boat approches hull speed it sinks further into the bow wave. As it does this, the overhangs are submerged, increasing the LWL even more.
slyrss3 is offline
post #22 of 36 Old 07-04-2007
RichH's Avatar
The CCA design was simply a 'ratings rule beater' and although the effective waterline (hull speed) did increase with boat speed, those large overhangs also produced a pronounced 'hobby-horse' motion when in waves ... which tend to slow down a boat.
RichH is offline
post #23 of 36 Old 07-04-2007
but man...are they beautifull....
Giulietta is offline
post #24 of 36 Old 07-04-2007
The long ends of the CCA style of boat also adds buoyancy in the ends and flattens out the buttocks at the ends which helps to keep you from being pooped while running. Also another characteristic of the style is narrow beam with slack bilges and a curve of area that is more symmetrical forward and aft then modern boats. Makes for a gentle motion at sea and promotes easy steering. In fact a lot of CCA boats will self-steer while very few modern boats will do this for more then a few minuets at a time.
All the best,
Robert Gainer
Tartan34C is offline
post #25 of 36 Old 07-04-2007
tomaz_423's Avatar
There is more than one LWL for each boat.
Some manufacturers even publish "static" and "dynamic" LWL.
When you are sitting flat in the water you can probably see that the stern is not touching the watter - there is some overhang. When you move (motor for example to eliminate heel from experiment) you can notice, than the faster you go the deeper the stern sinks and higher the water rises - extending the water length. Add heel and it is a bit longer again. Also the formula is not accurate for all boats. The narrow stern boats should use a bit smaller factor as the narrow stern can not support the weight of the boat even before the wave is at the end of the boat, so the stern sinks.
The boats with relative wide sterns can use larger factor because even when the wave is almost at the end of the stern it can still support the weight of the boat.
The factor is some sort of average for traditional design boats.
Of course very light boats with large sail plan are powerful enough to climb over their bow wave and start planning (most hi.perf. racers like America cup boats or Giu's boats), but than that is no longer displacement sailing.
Beneteau Oceanis 473
finished cruising after two years.
tomaz_423 is offline
post #26 of 36 Old 07-05-2007
CBinRI's Avatar
It has been my experience that hull speed is really just a useful guideline. I have been able to average higher than hull speed on some trips.
CBinRI is offline
post #27 of 36 Old 07-05-2007
humble pie rat
CapnHand's Avatar
So with fresh water being lower density than salt water, boats will float lower in fresh water. This gives them more water line. Will hull speed be greater in fresh water than in salt water?
CapnHand is offline
post #28 of 36 Old 07-05-2007
RichH's Avatar
Not due to density but freshwater has a lower absolute viscosity (and lower surface tension) than seawater ... therefore faster in fresh water.
RichH is offline
post #29 of 36 Old 07-06-2007
pigslo's Avatar
But if they sink further in the fresh water, they will have a lot more wetted surface and slow down.
pigslo
pigslo is offline
post #30 of 36 Old 07-06-2007
Here .. Pull this
When you sail fast boats (like a CS) in salt water you have to be careful because the boat moves through the water so fast that the friction makes the water boil and vaporise leaving salt crystals on your hull that slow it down....
Sailormann is offline
Hull speed and wide sterns Jeff_H Boat Review and Purchase Forum 24 11-21-2006 11:58 PM
Speed Week Redux Dan Dickison Racing Articles 0 09-27-2002 08:00 PM
Speed Sailing Overview Dan Dickison Racing Articles 0 05-16-2001 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
