07-06-2007
Here .. Pull this
Sure 'Canadian Sailcrafts made (make?) great boats' and all that but never mind the CS BS for now. Yes, there is more wetted surface in fw that slows you down. Yes, there is more waterline in fw that makes you faster. So, my question is; would a given monohull sailboat be faster in fresh water than salt water?
CS is making sailboats again and the world is a better place as a result  As far as the fresh vs salt speed differential goes, there may be a difference, but it's going to be pretty negligible. If a displacement hull is sitting an inch or two lower in the water, it may go 1/10th of a knot faster, IF you are moving through perfectly flat water. I don't think that you could find that flat water anywhere though...
