Ground Speed? How is it calculated? - SailNet Community
post #1 of 19 Old 07-16-2007 Thread Starter
NoDoubt's Avatar
I know if you’re going 4 knots and the current is 3 knots against you, your only making 1 knot ground speed, or if the current is 3 knots with you, you’re at 7 knots ground speed. But is there a calculation for ground speed when you are going cross current, say, 4 knots across a 3 knot current? I’m guessing you’d be at about 5 or 6 knots ground speed, but that’s just a guess.
NoDoubt is offline
post #2 of 19 Old 07-16-2007
trantor12020's Avatar
I suppose you can use trigonometry to caluclate. Draw a triangle 1 side 3kts length another 4kts length at right-angle to each other, the 3rd side length is your resultant speed and angle of your track (bearing other influence like wind).
trantor12020 is offline
post #3 of 19 Old 07-16-2007
You can calculate it mathematically—it's called trigonometry... or you could use the GPS to show you your SOG. Or you could draw the speed of the boat and the current graphically, and add the vectors to show you your SOG
sailingdog is offline
post #4 of 19 Old 07-16-2007
Re Member
knotaloud's Avatar
What your looking for is called the "vector sum". The two velocities are at right angles to each other, the vector sum can be determined using the Pythagorean theorem.
vresultant2 = (4kt)2 + (3kts)2
vresultant = Sqrt[ (4kt)2 + (3kts)2 ]
vresultant = 5 knots
or....
4 knots squared (16) + 3knots squared (9) = 25, and the square root of 25 = 5 knots!
But the real issue isn't usually speed, but how far off course the current is pushing you. To calculate this you need to calculate how long (time) it will take you to get a certain distance (say 100 nautical miles).
t = d/v
Once you know the time, then you miltiply that by the current (3 knots) to give you how many miles you'll be off course at the end of the 100 miles, and correct your heading from there.
Destination = v x t
So...
100 nautical miles at 5 vector sum, knots per hour = 20hrs, multiplied by 3 knots current = 60 miles that you will be off course for every 100 miles traveled.
Edit: Sorry about all the math
knotaloud is offline
post #5 of 19 Old 07-16-2007
Umm.
Knotaloud/trantor-
The current isn't always perpendicular to the wind... in fact 99% of the time it won't be, so the pythagorean theorum falls on its face. Also, knotaloud's equations should have been written
vresultant^2 = (4kt)^2 + (3kts)^2
rather than what you had, since the ^ is often used to express raising something to an exponent. Merely having the number outside the parentheses is usually assumed to mean multiplication.
Also, the current is not always going to be the only thing affecting your course. Leeway also affects your course, and may, in many cases, offset the set of the current to some degree, so basing your calculations on just the current's speed, which also may not be perpendicular to the line of travel, is less than accurate.
BTW, "T=D/V" is Distance = Velocity * Time, not Destination.
Finally, I generally recommend doing the calculations graphically, since it is far more difficult to screw them up by doing them graphically. Also, it can be done right on the chart. Any calculations for set and drift are going to be estimates...and a graphic solution generally will get you in the ball park, without a lot of math.... and the extra precision of the mathematics-based solutions is generally both unnecessary and inaccurate—it is like measuring with a micrometer and then marking with a piece of chalk... why bother—doing the calculations graphically is simpler and faster as a general rule...
And often, like in many other things where time is of the essence, a good answer in navigation right away is better than a perfect answer that takes four times as long... since there are often times you need to have idea of what to do immediately...and the extra time the equations take can put you closer to danger by delaying any decision you make.
post #6 of 19 Old 07-16-2007 Thread Starter
NoDoubt's Avatar
Knotaloud
Thanks for the math lesson, I actually understood it! But I think I'll stick with guessing for now!
NoDoubt is offline
post #7 of 19 Old 07-16-2007
moderate?
camaraderie's Avatar
NoDoubt...why guess? The speed shown on your GPS is speed over ground.
camaraderie is offline
post #8 of 19 Old 07-16-2007
kennya's Avatar
You can use this link to get course to steer and speed/knots made good
Course to Steer Calculator
kennya is offline
post #9 of 19 Old 07-16-2007
while i still prefer to do it with pencil and paper, my dad used a mechanical "flight computer" for such calculations (and others).
looked something like this:
his slider was customized because of speed range tho.
Tea-Rex is offline
post #10 of 19 Old 07-16-2007
Rickm505's Avatar
Try this spreadsheet, complete with formulas
http://www.merlinmortgage.biz/catalp...g_currents.xls
Rickm505 is offline
Speed Week Redux Dan Dickison Racing Articles 0 09-27-2002 08:00 PM
The Need for Speed Dan Dickison Racing Articles 0 10-03-2001 08:00 PM
Speed Sailing Overview Dan Dickison Racing Articles 0 05-16-2001 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
