Newbie questions about sailing - SailNet Community
post #1 of 11 Old 07-17-2007 Thread Starter
Sorry if the answers to some of these questions have been answered before, I tried to research but alas I can’t spend hours reading the forums (as much as I wish I could!).
I am completely new to sailing and I recently acquired an 18’ catamaran that is beyond repair. After doing a little research and talking to people I am in planning to strip the mast and other salvageable parts and build myself a sailboat. This is the boat I am currently looking at building:
GLEN-L 19
So my questions start here. What are 18-19’ sailboats capable of? The wife and I would mostly be taking it around the bay (Chesapeake) for now but are they capable of going up and down the east coast of the US? Can you even take these little ones out to sea much or should they mostly stick to shore?
Also on weekend or week long trips aboard how do dog’s handle being underway? Is it comparable to people that some take to it like ducks on water while others don’t want anything to do with it? We have a golden retriever and wish to take him with us on our boating trips.
CacheHunter is offline
post #2 of 11 Old 07-17-2007
NOLAsailing's Avatar
Dogs, like people, react differently and are even capable of becoming seasick.
If you have no sailing experience, you may not want to take to the waters of the Chesapeake on your own home built boat. Don't take it the wrong way, but that happened around here last summer and ended in tragedy with the couple drowning on their first outing.
I would suggest taking some sailing lessons and volunteering as crew on other people's race boats. You can also buy an older boat, like a Pearson Ensign, a Pearson Ariel, a Rhodes Meridian, a Southcoast 23, or myriad other solid and seaworthy boats for under $5000.
You need to know what you like and what does and does not work before you can build your own boat, in my opinion. Boats like those mentioned above usually provide plenty of opportunity for modification, while still maintaining both their seaworthiness and sail-ability.
-Jason
NOLAsailing is offline
post #3 of 11 Old 07-17-2007
CacheHunter-
There are some very capable 18-19' sailboats. Webb Chiles made it most of the way around the world in an 18' open Drascombe Lugger—but that's a bit of an extreme example. The Flicka, which is 20' LOD, has crossed oceans fairly frequently.
However, the Glen-L 19 you're looking to build is probably not seaworthy enough to go up the coast safely IMHO. It would probably be fine for sailing around the Chesapeake though.
Also, NOLA's point about home-built boats is very valid, and the cost of the materials and time it would take you to build the boat is probably comparable to what a smaller trailerable sailboat would cost you—ready to go out of the box, so to speak. While some of the boats he has named would probably not be as useful, being not suitable for trailering and generally requiring a marina slip, like the Ariel, there are a lot of decent performance, fairly seaworthy trailerable designs out there to pick from.
Whether a smaller boat can go out on the ocean has a lot to do with the design of the boat more than the length of the boat. There are 30' boats that I would be very hesitant to take anywhere off of a protected bay or large lake...and there are 20' designs that I would take out on the ocean.
As for dogs... that is really dog specific. Some dogs don't get seasick, others don't ever get used to the motion of the boat and are sick the whole time aboard. A golden retriever is probably a better choice than say a rotweiller... but may be a bit large for a 19' boat IMHO.
If you took the rig off of an 18' catamaran, it might make more sense to build a multihull to put the rig back onto.
sailingdog is offline
post #4 of 11 Old 07-17-2007
MysticSkipper's Avatar
It's all about displacement (within common designs) when you ask what a boat can do. Length plays a key role in how fast it can do it.
MysticSkipper is offline
post #5 of 11 Old 07-17-2007
I somehow missed the trailerability requirement. I think my bias for those old designs was showing through. They really are great boats.
As sailingdog points out, though, there are many small trailerables in the same range.
I also hope I didn't come across as too negative. If you really want to build your own boat, go for it. Just do it for the right reasons: cost is not the right reason - as both the material cost and time required is considerable.
Just get out on the water - as long as you do it safely - and have a great time. Best of luck to you.
-Jason
post #6 of 11 Old 07-17-2007
I am just guessing on the trailerability requirement, based on the design he chose, the GlenL-19 and the 18' catamaran that he had originally. Both are shallow draft and trailerable.
post #7 of 11 Old 07-17-2007
SENIOR CHIEF
USCGRET1990's Avatar
GLEN-L 19
It's pretty hard to make any boat "beyond repair" builing another is quite a task for the inexperienced. Send pics and info on what's wrong with the original cat and who knows, maybe it's salvageable...
USCGRET1990 is offline
post #8 of 11 Old 07-17-2007
A little less cheek
ianhlnd's Avatar
18 ft sailboats have gone around the world (or if they haven't they should have), Maybe, that's how S America go populated, guys from the pacific islands got swept eastward and became Mexicans. If you buy it and strip it, then you have to dispose of the hulk. Look at your local EPA requirements before you take the leak, no, I mean leap!
Just checking in.
Where ya'll keep'n the wimmin 'round here?
ianhlnd is offline
post #9 of 11 Old 07-18-2007
Here .. Pull this
If you are building the boat because you like the boatbuilding process then go for it. As far as 19 foot boats go - the specs seem to indicate that it will be fairly seaworthy. The ballast is maybe a little bit light but the boat has hard chines so that should provide some stability in lieu of the ballast.
If you "overbuilt" the boat - i.e.: reinforced it signifcantly, then it would prbably be okay for coastal cruising, but there are much better boats out there for that purpose.
Be aware that the cost of building it will be more than buying a used boat of similar size. Because it is a very dated design, and becuase it will be a homebuilt craft, you are not likely to be able to get much for it if/when you sell it.
You might want to consider these kits as well ...
Cape Henry 21 boat plans
Didi Mini radius chine plywood Mini-Transat boat plans
Didi 26 radius chine plywood boat plans
Boat plan details, Vagabond Plus 20 (VG20), Sailboats less than 25'
Boat plan details, Vagabond 23 (VG23), Sailboats less than 25'
Sailormann is offline
post #10 of 11 Old 07-18-2007
I think the Didi Mini Cruise would make more sense.
Newbie questions guyschwartz Boat Review and Purchase Forum 4 01-21-2004 05:44 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
Overlooked Books John Kretschmer Gear and Maintenance Articles 0 10-30-2001 07:00 PM
Single-Handed Sailing John Kretschmer Cruising Articles 0 10-19-1999 08:00 PM
The Joy of Night Sailing Sue & Larry Cruising Articles 0 05-31-1999 08:00 PM
