Lessons Learned Today (Vol. 1, Ch. 1) - SailNet Community
post #1 of 31 Old 08-05-2007 Thread Starter
The Admiral and I went on our first sail (on our own) on our new-to-us boat today. Here is what we learned (in order):
  • The lagoon in the middle of the canal we transit has an island in it. Stay at least 20' off that island going out, as the depth rapidly changes from 8' to 3.5'. This is detrimental to the forward motion of a boat that has a 5' draft.
  • Powerboats do have their uses. (See above.)
  • When attaching lines for towing, don't make 'em real permanent-like, as you may want to get 'em off quickly.
  • Don't get your digits between a rapidly tightening line and a cleat.
  • When attaching the main halyard, make sure it's behind all the shrouds, otherwise the main, she don't go all the way up.
  • When attaching the jib sheets, get 'em outside all the lifelines and stanchions, not just most of 'em.
  • Before assuming you ran both jib sheets incorrectly: Check. Otherwise you might find yourself having untied a perfectly good jib sheet.
  • When the forecast calls for a fairly significant change in wind direction, probably be best to get out well before said change is predicted to occur, or wait until well after, for odds are good that, if you're out there in the "middle," the wind, she will go away entirely.
Nonetheless: We did sail her, we did get her up to 4-1/2 kts in light and variable winds, and we didn't break anything .
Jim
SEMIJim is offline
post #2 of 31 Old 08-05-2007
Wish I never found SN!
SimonV's Avatar
How exciting, I am envious. May every day from now on be better than your first.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #3 of 31 Old 08-05-2007
Owner, Green Bay Packers
Sounds like a fairly standard initial voyage! If spouses are still speaking in pleasant tones, one could certainly call it a successful voyage. Congratulations.
Here's betting you will run aground again, but never in that same spot. Initial impressions are forever.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #4 of 31 Old 08-05-2007 Thread Starter
I guess "exciting" would be one way to put it .
Actually, we rather enjoyed ourselves. (Well, once we got un-stuck. That was kind of touch-and-go for a bit, there.) I guess I left-out the most important "lesson learned": Even a less-than-sterling sailing adventure is far-and-away better than no sailing adventure at all .
There were many things that went right. The Admiral did an admirable job of getting her in and out of the slip. (This despite a whole gaggle of people partying in little motor-powered inflatables right around our slip, as we were coming in. Some of whom were certainly at least mildy inebriated.) The genoa went up cleanly, which means I both packed it properly and bent it on properly. (Our boat has a Tuff Luff slotted headstay system.) And we learned a bunch of stuff w/o anybody or anything getting damaged or hurt. They say you learn more from making mistakes than getting it right, right?
Jim
SEMIJim is offline
post #5 of 31 Old 08-05-2007 Thread Starter
LOL!
Thanks . Yup, we were good. (More due to her than I, I must admit. She's a patient woman who I almost certainly don't deserve.) After I got her tied up (the boat, not the Admiral), we high-fived each other .
Yeah, St. Clair... well, there are plenty of opportunities, aren't there? No, probably not in that same spot again. We're going to be giving that spot wide berth .
Jim
SEMIJim is offline
post #6 of 31 Old 08-05-2007
teshannon's Avatar
Well done! That's called learning. I consider it a good day if I've come back without breaking anything. I don't always have good days but then I have an excuse to go work on the boat. Good luck.
Tom
teshannon is offline
post #7 of 31 Old 08-05-2007
runexe's Avatar
Powerboats can be useful
This is a lesson we learned just yesterday. We were out on our local sailing club's Hobie Wave, sailed out to ballast bay (about an hour away from the beach we launch from), tied up on a mooring just off the reef, and promptly capsized. This was not a big deal, until another gust of wind put the mast all the way into the water and she turned turtle. The two of us were unable to make any way on righting her at that point - partially I think do to the large rock the mast was catching on. Fortunately one of the local fishing boats was nearby - and came over to laugh at us when we waved them down. They were kind enough to stop laughing long enough to give a tug on the halyard and pull the mast out of the water, at which point we were able to get her rightside up again. At least they were friendly for a bunch of powerboaters .
runexe is offline
post #8 of 31 Old 08-05-2007
Jim
You back on Venetian?
xort is offline
post #9 of 31 Old 08-05-2007
SEMIJim-
Couldn't have been that exciting... the word capsize wasn't mentioned..
sailingdog is offline
post #10 of 31 Old 08-05-2007 Thread Starter
Originally Posted by xort View Post
Jim
Yup. Ended-up in a NSSC slip. Buddy's slips are too shallow . (The club re-dredges theirs, as necessary.) I'll be meeting with a member this coming weekend to get the paperwork started to join. Right now we're in the slip gratis. (Which is damn nice of of the club, I thought.)
Where are you at?
Jim
SEMIJim is offline
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Lessons Learned in Error Dan Dickison Racing Articles 0 05-24-2002 08:00 PM
Sailing to Simplicity: Life Lessons Learned at Sea John Rousmaniere Gear and Maintenance Articles 0 05-29-2000 08:00 PM
