Noob question re. overloaded sailing? - SailNet Community
Blogs
Old 08-08-2007
Pesky is on a distinguished road
Hi all,
Thought someone might offer some help.
I am learning to sail in a Snark. I went out with my two kids and so exceeded the weight limit of 310lbs!
Although we were a bit crowded, it wasn't too bad, but I seemed to have problems moving into the wind!
We had a light wind (3-5mph) and were tacking across it, but were moving slowly across to our 'destination'. The problem though, was that we were being pushed back (in the direct direction of the wind) and ended up pushed to shore everytime!
Yes, this was my first time out!
Next time I will try on my own.
Can I expect to actually move forward with just me in the boat?
The cap. is 310lbs, I am 190lbs.
Help!
Pesky
Old 08-08-2007
did you have the daggerboard in??
Old 08-08-2007
Yes
It was like "1 step forward, 10 steps back"!
Old 08-08-2007
danjarch's Avatar
Siren 17
danjarch will become famous soon enough
Having owned a snark, I'd bet money that you didn't have enough way on to make the tack. With only you in the boat, you should be able to pick up more speed. I sailed my snark overloaded more then a few times, but there was usually more then 3 to 5 Kts. When ever it was that light, she just couldn't get up to speed to tack worth a damn.
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
Old 08-08-2007
chris_gee is on a distinguished road
Your speed would be inversely proportional to the weight, and the drag would increase. Slower speed more leeway and less close to the wind.
Old 08-08-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
..huh...and I thought overloaded sailing was having too many cold ones...
Old 08-08-2007
camaraderie's Avatar
moderate?
I owned a Snark and weigh more than you...you need a stiff breeze to get her moving and going to windward is not the strong point of the boat...but they are lots of fun!
Old 08-08-2007
uspirate's Avatar
Trim for Sail
uspirate has a spectacular aura about uspirate has a spectacular aura about uspirate has a spectacular aura about
is that your snark in your avitar?
I bet with just you in the boat you will be able to make descent headway. then after you've mastered that, take your crew with you!
signature
BJ & Nimfa
S/V Flocerfida
Old 08-09-2007
sanctuarysam's Avatar
purveyor of mischief
sanctuarysam will become famous soon enough
uhm..depending where you were sailing the current could have been a factor..then again,if this was a lake outing.. in the immortal words of Emily Litella.."Nevermind"
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
Old 08-09-2007
moderate?
USP..yep...that is the new ketch rigged model...perfect for Lake Tahoe! (g)
Cats on Board slosharron Living Aboard 42 09-25-2011 04:14 AM
How Other Sailors Learned Mark Matthews Learning to Sail Articles 0 08-31-2001 09:00 PM
Sailing Inshore or Offshore SailNet Cruising Articles 0 03-13-2000 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
