08-13-2007
Best Looking Moderator
Sue,
This will, or could be, the beginning of a very long conversation. It is almost like asking which anchor is best. It is very opinionated. Thus, let me say that the typical cruiser with the typical sized boat has the following basic options:
1) Roll-up. I have owned one of these. They are attrocious performers. That is not an opinion (smile), it is a fact. You will be limited to slow speeds, low HP motors, and very difficult steerage. It has only three benefits as I see them: cheap, can roll-up for easy storage, and is light.
I personally feel that anyone who is at all serious about any kind of cruising should steer clear of these if possible. I will never own one again.
2) RIB. Rigid Inflateable Boats are very good performers and a pleasure to motor. They will break through the swells and will plane out. THis is important. Remember that your dink is one of the most used pieces of equipment on your boat while cruising. It was for us. We wore ours out. Also, this boat can be beached with little-no damage. The negatives on this boat are big, though. It is typically the most expensive and it is very heavy. Obviously, you are not putting this in your lazarette and trying to haul it up davits requires a lot of umph. Taking it on passages with it on your davits is a nightmare if you get caught in a storm... as is having it caught behind your boat. The bottom line is that while in the water, you will LOVE this tender. Getting it out of the water or anything else, you will hate it. Ours was a Avon 10'2 with the locker forward. Great boat with limitations.
3) HPIB. High Pressure Inflateable Boats. These boats have gained in popularity as the medium between the two above. They really are not much cheaper than a RIB, but they will plane out... somewhat. They will also fold up and deflate into a bag... somewhat. Their big negative is that they do not do either one really well. However, they are quite light for what they are and you "can" plane out. It requires more maintenance on these boats. For example, if your inflateable keel loses air and you do not realize it (happened to me this last weekend), you will think you are on a flat bottom roll-up again until you re-inflate. Obviously, we have one of these now. It is a Avon Hypalon 10'2. I honestly will say I am a bit dissapointed in this boat. We only have a 4-strk 6 hp on the back... but it is very hard to plane with much weight and when it does, it will not plane very well and steer well. It is, though, a compromise. If I was serious cruising, and especially be doing many passages, I would probably still consider.
Where you go from here is up to you. If I could go back, I might go back to a RIB. I do have davits and can get it up on them... but I remember getting that boat up there was such a pain I left it in the water half the time. It is also a lot of weight for smaller boats (36 and below, depending on the boat).
I hope that helps. If you have specifics, let me know.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
