Sun faded decals - scrap 'em? - Page 2 - SailNet Community
post #11 of 20 Old 08-27-2007 Thread Starter
arbarnhart's Avatar
My wife does scrapbooking and has some kind of magic stuff I can use if all else fails (I will try other things first as magic isn't cheap). The stuff she has is amazing. In the demo she saw for it, they removed a sticker from a piece of toilet paper without tearing it and in a few seconds after removal the sticker becomes sticky again. We have been very successful with using it on stickers and decals. I won't be real surprised if I can just peel it off though.
arbarnhart is offline
post #12 of 20 Old 08-27-2007
Yes, Easy-Off oven cleaner does contain lye or sodium hydroxide, but it is less than 5% by volume. It can damage some paints, which is why I said you had to be careful with it. It can also damage gelcoat....but it is often used to remove boat lettering without damaging the underlying laminate.
However, IIRC, it is better suited to removing hand-painted lettering and graphics, rather than vinyl decals.
A non-heat, non-chemical way to do this is to use a 3M stripping wheel, which is designed to remove vinyl pinstripes from cars. You can see it here.
Originally Posted by hellosailor View Post
s'dog, EasyOff is lye. It eats all kinds of paints and coatings AND softens fiberglass and gelcoat. Best not used on boats except in the galley, and if you do use it, make sure to do a acid wash (vinegar) afterwards to neutralize the alkali residue of the lye.
Yes, you CAN melt a boat.
sailingdog is offline
post #13 of 20 Old 08-27-2007 Thread Starter
arbarnhart's Avatar
The decals have virtually melded with the hull; you can see the edge, but cannot feel it with your fingernail. Now I fully understand why the PO left them there in their yellowed state.
post #14 of 20 Old 08-27-2007
RickLaPaz's Avatar
Easy Off should be regulated! A friend of mine years ago was trying to remove tar/asphalt from a rocker panel on a near-new bronco, and it took only 5 seconds to kill the top coats of paint. Very nasty.
It is an evil product............
RickLaPaz is offline
post #15 of 20 Old 08-27-2007
RickLaPaz's Avatar
BTW, I'd like to edit a bit---when I used the soapy razor blades on our boat, it WAS only to lift the decals. In the tropical heat, the rest of the sticker came off pretty easy. The Toluene part was used after the decals were off and to prep for the new ones. After I was done, I gave the area a quick buff and wax job by hand. Total time of project was maybe 2 hours, including a beer and a taco break. Plus it was 97 out..........
Rick
post #16 of 20 Old 08-28-2007
Live to Sail
HatterasJack's Avatar
Guy's and Gal's, Just a fantastic find I made while removing old letters and OLD stripes from our 31 Citation I thought I would share. Don't scrape or apply solvent! Go to any Auto detail shop and purchase a gummy rubber wheel (about $12.00). They use in a electric drill or buffer. This thing makes short work of the old mess and leaves your gel coat perfect and ready for the nice new one your print shop made.
HatterasJack is offline
post #17 of 20 Old 08-28-2007
3M pinstripe removing wheel....
post #18 of 20 Old 08-28-2007
Hitchin' a ride
bestfriend's Avatar
While we are on the subject. Where are we getting our new lettering from? I have 4 inch letters on the stern that need to be replaced. I know they sell them right here on sailnet, but are those any good? I need individual letters, not a one piece.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
bestfriend is offline
post #19 of 20 Old 08-28-2007
"but are those any good?"
With any vinyl signage, ask the maker exactly what vinyl they will be using.
3M and Gerber both make premium "exterior grade" or "marine grade" vinyl which will cost more--but carry a warranty of 5-7 years. It is thicker and uses denser pigments so it won't fade and chalk like some cheap stuff will.
There may be other brands that are just as good, but I'd prefer the 3M myself. Gerber [here] is a major maker of sign cutting machines and vinyl--not the same as the baby food or outdoor clothing companies, also with a top reputation.
A good shop won't sell you individual letters unless that's precisely what you need. They will cut the entire name/port and then place a "scrim" on top of the letters, so that you can peel away the excess from between the letters, apply the entire "sheet" of scrim, and then peel away the scrim layer, leaving just the letters, all in perfect alignment.
The scrim may be clear vinyl or "tissue" paper, no real difference either way. If you follow the instructions about applying the lettering (using a soapy spray or special solution they'll sell) and letting it dry in place before removing the scrim, it will come out very nicely.
hellosailor is offline
post #20 of 20 Old 08-28-2007
Hitchin' a ride
bestfriend's Avatar
Thanks HS. Yes, thats what I meant by individual letters. As long as it is not one big decal.
Vaya con Dios
Jeaneau Sun Fizz 40 Comments TimBowie Boat Review and Purchase Forum 16 11-09-2013 09:37 AM
USA. Jeanneau unveils new Philippe Briand designed Sun Odyssey - BYM News (press rele NewsReader News Feeds 0 07-20-2007 06:15 AM
On this date in The Sun: Sailing buffs flock to Big Bear Lake invitational (San Bernardino County Sun) NewsReader News Feeds 0 07-12-2006 04:15 AM
Frers 41 vs Sun Legend PhilMraz Boat Review and Purchase Forum 4 12-29-2004 02:42 PM
What Time Is It? Jim Sexton Her Sailnet Articles 0 03-24-2001 07:00 PM
