Genoa sheets - SailNet Community
post #1 of 3 Old 08-28-2007 Thread Starter
Genoa sheets
Have a 1976 O'Day 25. I am not sure what is the best way to run the genoa sheets back to the cockpit and to get them around the winch. The last thing I tried was this: sheets run from the sail, through the genoa car on the track, then through the cam cleat which is aft of the car, then forward to the winch.
Another possibility is to run the sheet through the genoa car, forward to the winch, then aft to the cam cleat. Either way looks strange and puts a lot of tension on the genoa car. In fact, the starboard one broke.
There is a fair lead on the deck forward of the winch but it is not adjustable and not in the right place for trimming a genoa. Works fine for the jib, though.
Any advice?
calamitas is offline
post #2 of 3 Old 08-28-2007
Siren 17
danjarch's Avatar
You might consider putting in another set of cleets that would be at a better fair lead. You might also upsize your genoa cars. You don't have any pictures of the rigging do you?
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
danjarch is offline
post #3 of 3 Old 08-28-2007
The genoa sheets should not be running through a cam cleat to get to the winch. Generally, the genoa sheets will run from the clew of the sail, back through the fairlead on the genoa car, to a turning block and then forward to the winch. From the winch they will either go to a cleat of some sort—usually clam or cam cleats, or if the winch is a self-tailer, they'll end in the tailing jaws.
Photos of the various pieces on your boat would help.... As would asking around on the O'Day group lists.
sailingdog is offline
Genoa/Jib Sheets - one continuous or two? chappyonice Gear & Maintenance 4 06-29-2007 12:25 PM
Knot usage for sheets and halyards Zanshin Gear & Maintenance 55 05-15-2007 08:35 AM
What is a Genoa? Kacper General Discussion (sailing related) 45 04-05-2007 03:23 PM
upwind Genoa trimming - lighter airs mikehoyt Racing 9 11-25-2004 03:32 AM
Adjustible Genoa Leads, Track & Teflon rick gleason Gear & Maintenance 5 11-28-2002 08:00 AM
