Going Dingy! - SailNet Community
post #1 of 6 Old 08-29-2007 Thread Starter
1977 Morgan OI 30
Joesaila's Avatar
Going Dingy!
I got a 'small' Westmarine Zodiac. Is there a technique for getting the outboard from the rail to the dingy that minimizes puncture or tipping? I'm glad no-one was filming yesterday and I now have a complete understanding of what a 'reverse pendelum' is. My 8 year old grandson pointed out that I was at risk of punching a hole in the floor with the outboard...me I was just fighting to stay upright. I ended up on my knees, go ahead, laugh and manhandled the little 3.5 into position. It was just as awkward getting it back to the rail. So tell me old salts....how do you do this?
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Joesaila is offline
post #2 of 6 Old 08-29-2007
Señor Member
TrueBlue's Avatar
Keeping a low center of gravity when moving the outboard is key to controlling that "reverse pendulum" effect you mentioned. The 3.5 is light enough for holding the outboard by it's end handle - with just one hand. That way the other hand is always gripping a rail, ladder, dinghy transom or tube for leverage. If you feel the motor is too heavy for you, install a crane off the cockpit.
I always keep the outboard below waist level whenever possible and lay the motor flat on the dinghy floor before entering - never do I sit the motor upright on it's skeg - even though we have a hard floor. It's just too easy to lose balance with relative weight distribution being so high. It's also sensible to keep one knee on the floor when lifting the motor to the transom for better balance.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #3 of 6 Old 08-29-2007
TB's advice is excellent, as usual. If you havea problem with doing that... get an outboard sling and just lower it to the a bit above where it needs to be, and then get in the dinghy, and partially mount it, remove the sling and then finish mounting it.
BTW, I cheat... I put the dinghy motor down on the ama deck and then get aboard the boat, and then move it to the railing mount where it lives when not in use... but you probably got no amas...
sailingdog is offline
post #4 of 6 Old 08-29-2007
Seen Your Mamba
AboardIndigo's Avatar
SD - what's an ama deck (I know - I'm full of questions. Just let me know if it gets annoying...)?
AboardIndigo is offline
post #5 of 6 Old 08-29-2007
Helms ALee!
tenuki's Avatar
It's where he attaches his training wheels to the boat.
tenuki is offline
post #6 of 6 Old 08-29-2007
Semper Gumby
GySgt's Avatar
Send a message via MSN to GySgt
I would like to see the drawing Gui would have for that one
GySgt is offline
Dingy - Seaworthy Brand ecgossett Gear & Maintenance 4 08-08-2007 09:38 PM
Cruising with a Hard Dingy on Davits LWinters Cruising & Liveaboard Forum 6 12-27-2006 08:32 PM
Dingy Questions PalmettoSailor Gear & Maintenance 10 07-26-2006 10:02 AM
Dingy Outboard Motor rclampitt Gear & Maintenance 6 01-21-2003 02:55 PM
Dingy davits 928frenzy Gear & Maintenance 0 06-18-2002 10:35 AM
