  #1
Old 08-29-2007
westerly33 is on a distinguished road
Captain Evgeniy Gvozdev circumnavigation
Hi there,
First, some historical notes.
There is a captain in Russia, Evgeniy Gvozdev, who made one single-handed circumnavigation in a 5.5 m sail boat – micro class racing boat.
Few years later he built a boat 3.6 m long in his apartment building kitchen, brought her down through the window and circumnavigated single-handed again.
Today, 4 years after his return he plans to go third time on a boat which should be 3m long. The boat now is under design. Going though the Roaring 40es is one of the options.
The question for today is – what type of heating device can be used on a boat this small?
It should not use electricity, should not consume oxygen from the cabin, and, ideally, should not use any fuel. Granted, it should be tiny.
If you want to know more about captain Gvozdev, here is his website:
://gvozdev.iwt.ru
It is in Russian but I can post some material here in English.
He is now finalizing a book about his adventures. It will be published in Russian some time in the future.
Alexei
  #2
Old 08-29-2007
I cannot post links since I am new here, so add http to the address I posted.
The site is slow and some times is not accessible. Sorry it is going to be better some time in the future.
Alexei
  #3
Old 08-29-2007
Stryker72's Avatar
Stryker72 is on a distinguished road
sounds like a perfect application for cold fusion!
  #4
Old 08-29-2007
sailhog has a spectacular aura about sailhog has a spectacular aura about
I would go with a wood stove. Make a nice rick of split oak, probably about 10-12 cord, and stack it up against the mast. This was the set up I used when I circumnavigated last year on my daughter's "Tortola Barbie" sloop. It's topsides and deck were hot pink and just over a foot long.
  #5
Old 08-29-2007
How do you heat if you don't use fuel... solar heat is about the only choice he's got left. And in the northern climes... it just won't cut it.
  #6
Old 08-29-2007
I bet you did not go to the Roaring 40s, did you?
  #7
Old 08-29-2007
Well, it was a bit of a joke, about fuel. I was just testing this new community.
Roaring 40s are in the South, may be it is better there?
In fact, the question is not a joke and resolving it proved to be very difficult and important.
  #8
Old 08-29-2007
TSteele65's Avatar
Ne'er Do Well
TSteele65 is on a distinguished road
  #9
Old 08-29-2007
Screaming Sixties for me. The "Tortola Barbie" sloop was really poorly made. The plastic hull flexed, and it turned out to be just too small with all that wood onboard. Lead poisoning became a problem (it was made at the Milton Bradley factory in China). The head was tiny -- only one inch wide -- which left a big mess after each bowel movement. I could go on and on...
  #10
Old 08-29-2007
Technically, Mr. Fusion still uses fuel...
You may post attachments
You may edit your posts
Experienced Captain Available - Sailing or Motor Yacht jim0123r Crew Wanted/Available 2 02-06-2008 11:33 AM
Sharing your faith while cruising Missionary Cruising & Liveaboard Forum 184 07-13-2007 12:42 AM
Captain a Worldwide Expedition! reachtheworld Crew Wanted/Available 0 07-28-2005 09:17 AM
"FREE" USCG Captain for worldwide deliveries. rumcay Crew Wanted/Available 5 03-14-2003 02:43 AM
Sailing School versus Captain Mark Matthews Learning to Sail Articles 0 09-22-2000 08:00 PM
SEO by vBSEO 3.6.1
