Need ideas on how to raise a sunk boat. - Page 2 - SailNet Community
post #11 of 35 Old 09-03-2007 Thread Starter
'72 Pearson 36
SVDistantStar's Avatar
Send a message via AIM to SVDistantStar
The boat sank since the cockpit scuppers are clogged and dont let it drain. Its been raining for the last few days and i just hadn't had the chance to get out there and run the pump.
I think we can get it floating with the airbeds and then move it into shalower water.
Pingpong balls would come out of it in a hurry, both side windows are broken out. This was my project boat that i havent had the money to haul out and bring home yet.
SVDistantStar is offline
post #12 of 35 Old 09-03-2007
Roadkillibus Texanis
retclt's Avatar
While scuba diving a local lake a few years ago we moved a sunken Ford van by filling a bunch of tire inner tubes inside it. They work pretty well because you can squeeze them into all kinds of small places. You can get a bunch of them for real cheap. We moved it as a practical joke to other divers who frequented the area. Some of those guy's are probably still looking for it.
Sorry to hear about the bad luck.
I'd like to add a safety caution. It was not a safe thing we did and I would never move that van again. It was very unstable and dangerous. Deflating / popping those tubes scared the $#!% out of us. You're just going straight up. I wouldn't mind that.
Bob T
"I cannot not sail" - E. B. White
Last edited by retclt; 09-03-2007 at 07:03 PM. Reason: Adding a caution statement.
retclt is offline
post #13 of 35 Old 09-03-2007
Originally Posted by sharkbait View Post
I saw an episode of mythbusters where they did it with pingpong balls. It took alot of balls.
Thatís a real thing and it was done to raise a cattle boat in the Far East somewhere but the location escapes me just now. It was also tried unsuccessfully during a salvage attempt on the Andrea Doria sunk off RI after a collision with the Stockholm. They used small balls that were just a little bigger then a Ping-Pong ball and pumped them down into the ships. They didnít stay in the Andrea Doria and the sea was covered for miles with the balls after the attempt.
All the best,
Robert Gainer
Tartan34C is offline
post #14 of 35 Old 09-03-2007
retclt's Avatar
Have you seen the price of ping pong balls?
Bob T
retclt is offline
post #15 of 35 Old 09-03-2007
I bet you get a good discount if you buy 7,000,000,000 at a time. Actually, I donít think they used Ping-Pong balls but instead made hollow spheres on site to pump into the ships.
All the best,
Robert Gainer
post #16 of 35 Old 09-03-2007
Look at this site, www.iusmentis.com/patents/priorart/donaldduck/ it has some background on the Ping-Pong ball salvage method.
All the best,
Robert Gainer
post #17 of 35 Old 09-03-2007
I'd go with floatation in the cabin, which should pull it up most of the way. Air mattresses, inner tubes, used polythene barrels (from a photo processor or bulk food importer--they both throw them away) would do. Remember that the air will expand in volume as the boat rises--so your "balloons" will burst unless they can also double in size or vent. If you use air mattresses or inner tubes, only inflate them half?way.
If you can get it off the bottom and rig a bridle around it, so you can put floats on either side and secure them low down, then you may be able to float it up the rest of the wayto the point where you can open the drains/seacocks and get it dewatered signficantly by itself.
Home Depot and tool rental stores all rent "trash pumps" that can get the rest out, once you beach the boat.
Just remember-things can and will shift unexpectedly, this can be dangerous. If you can find a local vendor who uses a small crane to move large moorings--they may be able to lift it all the way up and out, if your diver friends can rig the slings on it properly. Might be worth the expense to just get it done that way, without risking anyone while it is in motion.
hellosailor is offline
post #18 of 35 Old 09-03-2007
One of None
deniseO30's Avatar
there is a formula
to figure out how much floatation (for example)a barrel would have.. is it something like the gallons it holds? The weight of a gal of water is about 9 lbs. so a 30 gal barrel would displace 30 gals of water X 9? = 270 lbs? I'm sure I'm wrong but it seems logical enough. How about kids beach balls? bigger then pingpong for sure. This time of the yr most beach stuff is on sale already. I'm guessing it won't take allot of floatation to get her off the bottom and towed into shore. Could it be considered lucky its only in 15ft or water?
Good luck!
deniseO30 is offline
post #19 of 35 Old 09-03-2007
Owner, Green Bay Packers
Internally lifting the boat is presuming upon a strong deck to hull joint on a boat already scheduled for refurbishment. It may be just the ticket for raising the deck alone.(g)
ďScientists are people who build the Brooklyn Bridge and then buy it.Ē
Wm. F. Buckley, Jr.
sailaway21 is offline
post #20 of 35 Old 09-03-2007
About 64.1# per cubic foot for seawater, and displacement is usually figured by volume, not gallons. About 8.5# per gallon.
Ping pong balls, like eggs, are fairly incompressible. Beach balls compress and expand and blow out, and have weak valves in them. Very different.
Blowing the deck off...I guess that depends on how lightly the boat is built and how much is rotted out. I'd expect typical bulkheads and deck joints to hold for the short time they'd need to.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Sailing Basics Steve Colgate Learning to Sail Articles 0 03-09-2003 07:00 PM
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 07:00 PM
Understanding the Racing Rules, Part Three Dean Brenner Racing Articles 0 09-09-2002 08:00 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 08:00 PM
How to Choose the Right Boat Don Casey Cruising Articles 0 04-20-1999 08:00 PM
