Report Max Fun 35 Keel Failure - SailNet Community
post #1 of 27 Old 09-12-2007 Thread Starter
1997 Dehler 33
max-on's Avatar
After reading the Tartan / C&C discussion I kept thinking about the responsibilities of a builder to the owners to build a quality product. After all, it is a boat, not a washing machine or a piece of patio furniture, and whether we are ten miles from the coast or 500 miles offshore, we put our trust and lives, and the lives of our family and friends, in the construction of the boat.
This is copy of material on the front page of SA today, and I think the linked report illustrates just how serious things can go wrong and the associated consequences - the loss of life.
A Look at What Happened
When the Max Fun 35's first came along, we thought they really looked great - a nice fast sport boat with some interior. Proving that looks can be deceiving, here is a very sobering report on the keel failure, capsize, and loss of life from a Max Fun 35 named Hooligan 5 from the UK. It is a very comprehensive report that uncovers some startling short cuts, lack of proper engineering and poor build standards that resulted in this tragedy.
(I hope this site and members are not offended that I am posting material from another sailing site)
max-on is offline
post #2 of 27 Old 09-12-2007
Same thing happened with Bavaria sailboats not too long ago...
sailingdog is offline
post #3 of 27 Old 09-12-2007
Once known as Hartley18
Classic30's Avatar
Dock
I guess the moral of the story is: If you're going to buy a boat and do some serious sailing (not just cruising the marinas within a few NMs), buy an old, solid boat - the older the better - built in the days when everything was oversized and not just built to a price.
...Like a Hartley! :-)
--Cameron
Classic30 is offline
post #4 of 27 Old 09-12-2007
Holly s*****...have you noticed how similar that keel is to mine??
And how similar my boat is to that one?
I have a similar keel attachment arrangment, with the tapered box and all, but my keel is a one piece core beam, not welded as that one, so I'm ok, I hope...
However..next year its coming off for inspection anyway, so good time to check it.
sad...sorry for the human loss
Giulietta is offline
post #5 of 27 Old 09-12-2007
moderate?
camaraderie's Avatar
Max-on...no problem here with using other sources as long as one attributes and links and only engages in "fair use" rather than any copyright violation. We're always up for an interesting story as this tragically was.
Giu...that is the first thing I thought when i looked at the blue boat in the report!
camaraderie is offline
post #6 of 27 Old 09-12-2007
--Cameron
That's not true, please don't say that. That's a racing boat, its designed to whitstand more forces than any other boat.
My boat, that has pretty much the same purpose can sail in higher winds, at higher speeds, higher stresses and in conditions the "good old strong boat" would be sinking, and/or reefing and motor home is not like that at all, and so aren't many of the other thousands of race boats out there.
What happen here is pure indirect negligence by the builder, that should have monitored keel-subcontractor manufacturing techniques, and didn't.
The contractor cheated, and the builder did not know..
Both are liable for this. Don't blame the boat or anything else.
post #7 of 27 Old 09-12-2007
tdw
Super Fuzzy Moderator
tdw's Avatar
Tch Tch Tch. I'm telling. Nyah Nyah Nyah. You just want to catch up on the Double Reef / Daniel Taylor train wreck.
Memo to self - if ever you feel like calling Sway a blowhard have a quick read of a DR thread.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #8 of 27 Old 09-12-2007
Cam...I guess I am safe.
You can see here the design of mine is quite different.
Mine has solid steel piece from the torpedo to the top. Its then coverd with the 2 halves in CF that shape the keel.
Then on top, there are 2 studs that cross the steel to fix the keel to the shapped structure bonded by CF to the hull.
Then on top 3 bolts make sure it goe no where...
post #9 of 27 Old 09-13-2007
Classic30's Avatar
Dock
Apologies, Guiletta - I did not mean to upset you.
I've read the report quite a while back now and from what I remember, the designer cut a few corners too - he just didn't envisage anyone cutting any more.
Having sailed on many "old boats", I, personally, would rather go to sea in one of them than one of these new "plastic-fantastics" - the designers back then (Holland, Uffa Fox, S&S, etc.) didn't have the advantages of modern glues and materials, so they made sure things were really solid.
I remember standing on the dock after the 1984 Sydney-Hobart and being amazed at the damage done to the newer yachts whilst some of older yachts were relatively unscathed.
--Cameron
post #10 of 27 Old 09-13-2007
SD, Not the same at all. nada nothing, zilch...
Bavaria 38 Match keels were simply bolted to the hull, with minimal stiffening other than increased hull thicness where the bolts went thru. They were relying ion the kevlar mat they were installing in the other slower bavarias.
This boat has a keel box, just like mine, its an opening likle a upsidown box, that has no connection to boat inside, other than the vertical bolts.
The keel enters that box, the bavarias was flush with hull.
This keel seems to me as being well designed, but the manufacturing unfortunately was defective.
But the bavaria incident and this are completely differnt. Bavari simply had no engineering whatsoever.
Still this does not excuse the builder from its rsponsabilities. It was his job, when sub-contracting to make sure contractor works as should.
If the build was made as per design then failed, then it woulçd be the designers fault.
Cameron, no need to appogize, really, I was not mad, just did not agree with you, my way...sorry, But its ok..we're still friends
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 17 07-30-2014 09:23 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
