Ships Barometer & Clock - needs repair - SailNet Community
post #1 of 7 Old 09-17-2007 Thread Starter
New Sailors Jane & Bernd
Windermere's Avatar
Hello! Could anyone recommend a place to have my ship barometer & clock looked at? Neither seems to be working, but I'd like them too!
Windermere is offline
post #2 of 7 Old 09-17-2007
Pamlicotraveler's Avatar
What make is it? Weems & Plath?
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #3 of 7 Old 09-17-2007
Most common maker is Weems and Plath and they will repair their instruments, might want to check current prices for your model to determine if cheaper to repair or replace.
http://www.weems-plath.com/custserv.html
capttb is offline
post #4 of 7 Old 09-17-2007
Seņor Member
TrueBlue's Avatar
An aneroid barometer is the type typically found on boats and usually does not require service or repair. Since it registers changes in atmospheric pressure though a pointer activated by a contracting or expanding vacuum bellows, no electrical current or batteries are required.
Keep in mind that the pointer will move very gradually, so you may not notice much change - therefore it may still work without realizing it. Generally, if the pointer moves toward low pressure, it means oncoming bad weather, high pressure means the onset of good weather.
The ship's clock of course, does require either electrical energy to power a motor, or a mechanical spring needing periodic winding. Check to see which type you have and maybe the problem will be solved. Otherwise, I would bring the instruments to a local watch/clock repair shop for their analysis.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #5 of 7 Old 09-18-2007 Thread Starter
Windermere's Avatar
Thank you all for the help and ideas. The maker is Watrous, German maybe? I don't know that they are anything special. Maybe I will look into replacing instead, I don't think that the barometer needle has ever moved since we've had it.
post #6 of 7 Old 09-18-2007
Wayne25's Avatar
Windermere:
Did a fast google. Found this http://www.theweatherstore.com/frwashwhba.html
Looks like nice instruments.
Wayne25 is offline
post #7 of 7 Old 09-19-2007 Thread Starter
Windermere's Avatar
Thank you Wayne25! I put a call into them this morning about repair. Jane
Understanding Time for Navigation Jim Sexton Seamanship Articles 0 10-14-2004 09:00 PM
Sail Repairs at Sea Brian Hancock Gear and Maintenance Articles 0 09-22-2003 09:00 PM
Sail Repair 101 Don Casey Cruising Articles 0 03-10-2003 08:00 PM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 08:00 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 09:00 PM
