Old 09-19-2007
CaseyJones's Avatar
CaseyJones is on a distinguished road
Ran aground .. advice?
This is my first post, been reading the forums for a little while..
I sailed a lot as a kid, and recently got back into it after a few years of not sailing
So a friend and I were cruising on his Tanzer 22 on Lac Deschene, and we suffered a touch of 'is that the channel marker or the shoal marker?' ..
.. Well.. it was the shoal marker.. .. sailing on a close reach in light winds, doing maybe 4 knots and *thud* / slight bounce we come to a dead stop..
Dropped the sails immediately and kicked on the outboard while trying to heel the boat using our weight .. we were able to pivot around a full 360 degrees, but not make headway in any direction, so it looks like our keel hit and bounced on top of a rock
Thankfully it was race night and a crashboat heard our whistle.. A couple of friendly gents took our spring line and towed us our while we hung off the port shroud to heel the boat as much as possible..
no discernable 'scraping' or knocking as we came free.. so i guess we were not held as badly as we thought..
checkd the bilge when we got back to the marina, and it was was dry as a bone as were the keel screws (what's the proper term for those) .. Anyways we're wondering 'how bad could the damage be?' and should we haul it out early, or let it soak as long as possible to see if there's any cracks or leaks that may surface over the next few weeks.
Any advice is appreciated! .. It was quite a scare, and the first grounding for both of us.. .. a story to tell and a learning experience that *hopefully* won't result in an expensive repair ..
Old 09-19-2007
camaraderie's Avatar
moderate?
Sounds like little to no damage done. I'd just keep an eye on things around the keel bolts and wait to assess any damage at your normal haulout which can't be too far away! We all hit bottom and most boats are tougher than we think and most damage is immediately evident if serious. Chances are all you will need it a bottom paint touch up. Welcome aboard!!
Old 09-19-2007
Bardo's Avatar
Just another stop...
Bardo is on a distinguished road
Yes, we are all "well grounded" in the sailing experience around here!
Old 09-19-2007
Casey-
Doesn't sound like too bad a grounding... Just remember there are two types of sailors—those who go aground and those who lie about never going aground.
Old 09-19-2007
CaseyJones's Avatar
Oh I'll admit to my own stupidity any day of the week! .. I'm just happy my first experience grounding was in a relatively indestructible Tanzer 22 ! .. Apparenltly they're well known for their ability to take a beating and sail away from it
We made the mistake of following the guy ahead of us isntead of reading and thinking about the markers.. he cut the buoy on the wrong side too, but got lucky
Never assume the guy in the other boat knows what he's doing I suppose
Old 09-19-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
With the motor running, trying running out the jib to heel the boat over. Unless you're really stuck, that usually does the trick.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 09-19-2007
I ran aground a few times...but never on a full keel boat...yet...and I hope not to do it....
However, this summer, on a particular anchoring place, when the tide went down, my keel touch the ground, and we had a 10ş list....so she's not a virgin anymore...bottom was sand. Took the opportunity to clean water line on one side!!
Old 09-19-2007
Giu-
You have ten feet of draft.... I take it you were using the dinghy to clean the bottom..
Old 09-19-2007
Pamlicotraveler's Avatar
Pamlicotraveler is on a distinguished road
Dropped the sails immediately and kicked on the outboard while trying to heel the boat using our weight .. we were able to pivot around a full 360 ..
I wouldn't have dropped the sails....I would have cranked the engine to hopefully get pointed in the right direction and then put up more sail.
I'm in North Carolina, so I can think of very few sailing seasons when I haven't hit ground. I've had anchors on halyards and winches many times. But fortunately it's usely mud around here.
The next best thing
To playing and winning is playing and losing.
Robert Lee Castleman
Old 09-19-2007
sailhog has a spectacular aura about sailhog has a spectacular aura about
I try to do as little as possible and let the tide come up. Keep an eye on the health of your impeller if you run the engine after running aground...
Sailboat carrying 24 runs aground near Newport, 1 injured - Providence Eyewitness New NewsReader News Feeds 0 07-31-2007 10:15 PM
Sailboat carrying 24 runs aground near Newport, 1 injured - MyFOX Providence WNAC NewsReader News Feeds 0 07-28-2007 09:15 AM
Man Rescued After Sailboat Runs Aground (Wed. 11.01.06 - Cape May County Herald NewsReader News Feeds 0 11-26-2006 01:15 PM
What to Do When You Run Aground Sue & Larry Her Sailnet Articles 0 12-18-2002 07:00 PM
Thoughts on Running Aground Mark Matthews Racing Articles 0 08-06-2001 08:00 PM
