- Quick Menu
10-02-2007
motorcycle on a boat?
How would you put a small motorbike on a 30ft boat? Also, what kind of bike would you want to have, if your intent was to sail throught the great lakes, 3 days at a time, and returning home for a week in between each leg?
10-02-2007
Wandering Aimlessly
I have enough trouble with a bicycle on my 32 foot boat.
It would certainly mean being at a dock to off load it, and that's quite a bit of weight to have come loose in a storm. For only being out 3 days at a time, trying to cart around a motorcycle seems a bit like overkill, aside from not being very practical, or even, as far as I can see, useful.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
10-02-2007
Larus Marinus
I would chose the lightest most easily compressed bike that would take me back to my car, left at the previous port of call. It needs to get in the back of the car as well as on deck. Lift it on deck with a halyard and lash it down well under or in a protective bag.
10-02-2007
John, where do you store your bicycle ?
S/V Scheherazade
Tony Orlando stand in and Burt Reynold's stunt double.
10-02-2007
Even a small motorcycle, if it is street legal, is going to be an issue on a 30' boat. You probably don't want to store it below... since the motorcycle has gasoline in the tank... and getting it down the companionway on a 30' boat would be a challenge on most of them. Storing it on deck means that it has to be stored across the stern in some fashion, otherwise it will affect the boat's balance. Having that much weight aft, is going to screw the fore-aft balance of the boat in any case.
If you're new to the Sailnet Forums... please read this POST.
10-02-2007
Larus Marinus
Are monkey bikes legal in the US?
http://www.monkeybike.co.uk/index.html
Still 60 kg is too heavy. - Get a bicycle.
10-02-2007
Wandering Aimlessly
Free - for now, just on the side deck. For offshore, I may put it in the cabin.
John
Ontario 32 - Aria
10-02-2007
Thanks, That works, I tend to walk down one side most of the time, anyway.
S/V Scheherazade
10-02-2007
Belliure 41'
I had a BMW K1200RS on the deck of my 33 Irwin about a year ago. I put the bike against the mast (on the bow side) with an extra tire between the bike and the metal. I then put the transmission into first, put a rotor lock through the front wheel, closed the gas valve and tied it up. Went out into some decent wind and waves, the bike never moved or got a scratch on it. Just make sure cabin top can take the weight and you have an emergency plan to get the bike off should you have a problem.
Wish I had a picture, could have gotten that Darwin award I always wanted.
“Greatness Is Not In Where We Stand, But In What Direction We Are Moving. We Must Sail Sometimes With The Wind And Sometimes Against It – But Sail We Must, And Not Drift, Nor Lie At Anchor.”
Oliver Wendell Holmes
10-02-2007
How much does a K1200RS weigh? Personally, I wouldn't put anything heavier than a crew on deck, and I have a steel 40 footer. Lashing to the mast is probably your best option (complete with a total tarp cover), but it's not a good idea on a sub 40 footer, I think...too much to go wrong. Think of having that dead weight on one side of the mast when you are pounding with the bike on the lee side...the shrouds are holding the mast in column PLUS the weight of the bike just hanging at 20 degrees or more, whereas a person would actively spread their weight on non-skid and wouldn't usually be just hanging off the mast unsupported.
No, I do not like this, Sam I Am.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
