-   -   Hailing Port Question (http://www.sailnet.com/forums/general-discussion-sailing-related/37373-hailing-port-question.html)
saltypat 10-04-2007 04:25 PM
I am in the process of putting name and hailing port on our boat.
I have decided to document it also (it was documented before, so it is easy to do).
The USCG says hailing port should be in 4 inch letters- Should I make it all caps 4 inches high? I would like to make it in caps and lower case, but then the lowercase letters would not be 4" high, so I am assuming that is not an option.
Is this correct? Just doublechecking, Thanks-
SaltyPat
hazmat17 10-04-2007 04:29 PM
I can't recall seeing a mix of caps and lowercase on a sailing port.
That said, What (if any) penalties are there for not following the "rules". A little civil disobedience is good once in a while, hint hint.
poopdeckpappy 10-04-2007 05:10 PM
I'm 99% sure you can go with 4" capital then smaller lower case for your Home port name, I see it all the time
sailingdog 10-04-2007 11:38 PM
I've seen them in upper and lower case... as long as the CAP height is 4", you should be alright.
camaraderie 10-05-2007 11:00 AM
The requirement is that all letters are 4" high. Nevertheless, I don't think Homeland Security will be out looking for you if you don't do all caps.
