04-03-2002
Mooring and Battery Power
Good Morning MSam,
Here,s whats up with hooking a turbine up. You'' ve have the mast that the unit sits ontop of, (usually on the transom but also on top of the main or mizzen mast, on the front of themizzen mast or from the rigging) two supports that sit 90 degrees of each other, and three wires, red black and green, exiting through the bottom of the yaw bearing. Thats it! And the installation is really pretty simple, and once you put it up... thats it, period. (at least with the Air Marine).
Now... the problem I had with plugging the ac output from the gen. into the ships ac recepticle is that it made my charger make a strange hum; I didn''t trust that so I hung it on the stearn rail, made- up wires and ran the D.C. output to the batterys. May I suggest that if you choose to do this mount a weather proof plug on the transom and hard wire the D.C. charging wires to the batts. cause they will get in your way and their a pain to set-up and put away.
Solar pannels are very expensive for their performance. I don''t think their worth it unless you are doing some serious crusing and have a large battery bank and even then their only suplemental. They only give their rated power if the sun is shining directly perpendicularly on them and only if the sky is clear and only if it''s day time. If the conditions are perfect, you will only get about six to ten amps amps and thats after paying 800 to1,300 dollars. Their are smaller ones.
My Air Marine starts-up at six Kts. of wind with 1/4 amp of output, 2.5 amps at 10 Kts., 7.5 at 15 kts., 20 amps at 20 Kts. and up to 40 amps. If you want, I''ll get into it further in the next post, there''s much more!
Yes, people run their engines alot and it''s not good to run a diesel at a small load. Besides do you really want to use an expensive engine, worth thousands of dollars, to charge a couple hundred dollars worth of batts?
Well, I gotta go. Talk with you latter.
Dennis
P. S. Can anybody shed some light on as to why my charger made that hum when ran by the generator?
thankx,
Dennis
