Tender Engine - SailNet Community
post #1 of 4 Old 10-23-2007 Thread Starter
Tender Engine
Looking for 8 hp standard outboard engine for new dingy/tender. Need direction on outboard engines that are reliable, easy to start. Lots of claims out there but what is the experience on the waterfront? Where is the value?
Mark O. Flaherty
Diversion, Norfolk VA
markoflaherty is offline
post #2 of 4 Old 10-23-2007
British Seagull is in my opinion the best outboard ever made. Simple, easy to repair or service and almost indestructible. Large slow turning propeller so it has more usable power then the rating suggests. I have moved 100 ton boats with a Seagull. The only real problem is finding someone willing to sell one. I wonít part with any of mine.
If you canít find a Seagull use a Suzuki. I have one and it's fine.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didnít work before.
Donít waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
Tartan34C is offline
post #3 of 4 Old 10-23-2007
Best Looking MALE Mod
Cruisingdad's Avatar
The best one I have had so far is a Yamaha. BTW, you did not think there would actually be a consensus on this, did you!!??
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #4 of 4 Old 10-25-2007
'72 Pearson 36
SVDistantStar's Avatar
Send a message via AIM to SVDistantStar
Ive got a 1991 Johnson 3hp that has been one damn fine motor. Its 2cyl, so it runs smooth and has the power of a 5hp. Ive gathered 3 more of them to keep mine going, still have 3 compleat parts motors setting at my granddads.
SVDistantStar is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
