Old 10-28-2007
deniseO30's Avatar
Lies about her age
Dirty Jobs
Mike Rowe should do a show on pumping/cleaning holding tanks, changing oil, and bottom washing a sailboat! But I suppose those jobs would be minor to some of the things he's had to do. Skelton recovery would be top of the list ew!
Old 10-28-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
He lives in the neighborhood that I work in. He is a very nice guy, he walks by all the time and we talk to him. Very funny too.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 10-28-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Did that today, for the first time ever in my life. Would've been significantly easier were it not for the fact our pump-out port's top few threads are bad, so we have to remove the washer from the adaptor to get it to thread, which meant a slight air leak, which meant reduced pump-out performance. But we got her done. Did the vinegar and baking soda cleaning before-hand. Pumped 'er out, filled 'er up with water, pumped 'er out again. Will pump a gallon of purple stuff in thru the head as part of winterization.
changing oil,
That comes later this week, along with winterizing the coolant system with purple stuff.
That'll get done during haul-out, next weekend .
Then I get to build a frame to tent the tarp. Then we tarp her. Then I can start contemplating a couple of after-haul-out projects, such as rebuild the head's pump, replace the packing in the packing gland, and add a strainer to the fresh-water intake line. Probably would be a Good Idea to trace and document all the wiring, too. (And correct the stuff that isn't up to my standards.) Then there's various wood bits that'll probably be removed and will go home for refinishing... such as the companionway steps...
Then, when April rolls around, she goes back in the water with a fresh coat of bottom paint. Yay!
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-29-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Clearly you've never held the business end of a pressurized pumpout hose when a fitting failed. I guarantee there's nothing minor about it!
"Clean bottoms are FastBottoms"
Old 10-29-2007
SEMIJim's Avatar
I'm told that (implosion) only happens with overly aggressive pump-out systems and/or when tank vents are plugged.
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-29-2007
Fstbttms's Avatar
I wasn't talking about an implosion. As the owner of a pumpout service, I see a lot of funky pumpout station setups (we have to offload the pumpout boat, too) and on more than one ocassion I, or one of my boat drivers, have been the victim of jury-rigged equipment.
Old 10-29-2007
deniseO30's Avatar
Lies about her age
fsstbttms I agree with you on the setups Marinas have for pumpouts. My dad was a plumber ... Yes, I DO KNOW just what you mean. That's all I'm going to say...except I'm sorry you had to suffer such misfortune also!
Old 10-29-2007
Fstbttms's Avatar
Hey, that's what hepatitis shots are for!
Old 10-29-2007
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
On submarines the holding tanks are blown out with 700psi air pumped into the tank, then opened overboard.
Within the toliet is a stainless steel ball joint about 3 inches around. While blowing there is a constant hiss of escaping air and concommitent bubbling of various liquids.
Prior to blowing the tanks they go around and 'tag out' (hang a red tag) on the flush handle and the door to the head to make sure no one inadvertently gets a 700psi enema.
It still happens, and if you blow it, you clean it - from everywhere, regardless of your rank or position on the boat.
Old 10-29-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
During a dock party last year, we had a few dockmates over for some drinks. One of the female guests, somewhat inebriated and unknowledgable with Lavac heads, asked to use the conveniences.
A few minutes had passed when an alarming scream emanated from the head - prompting another female guest to offer her assistance. It seems she had pumped the Lavac's flush lever - which relies upon a vacuum to empty the bowl's contents . . . while still seated. After a minute, pressure subsided - but not without experiencing a near enema event.
True Blue . . .
sold the Nauticat
gross jobs :( BarryL Gear & Maintenance 20 09-23-2007 01:50 PM
Dirty Foods ? GordMay Provisioning 28 07-26-2007 04:07 PM
Jobs for sailing blastoff General Discussion (sailing related) 3 07-25-2006 11:33 PM
Jobs Jeffamc General Discussion (sailing related) 5 12-23-2003 08:02 AM
Sailing Jobs Mark Matthews Cruising Articles 0 10-13-2002 08:00 PM
