11-17-2007
You might want to check out JiWire.com. It has a database of free and paid WiFi hotspots. I wouldn't pay for the amplifier and antenna...since a good PCMCIA card with a directional antenna will have fairly decent range and can be had for under $100. The legal maximum on transmit power for WiFi is 200 mW. The problem with the highly directional antennas is that a boat isn't really a stable enough platform for them to work well. The best antenna for a boat is probably something like a 6-9 dB gain patch or panel antenna with about a 90˚ coverage angle...since that would allow for some movement of the boat.
If you really need coverage and you have a cellphone, you might consider getting a cellular data plan. This works best if your phone and laptop are both BlueTooth equipped.
