12-03-2007
Best Looking Moderator
My "guess" is in the water, since there will be less surface area exposed. It also seems to me that the higher you are from the ground, the stronger the winds. Of course, if the marina you are at does not have strong pilings/docks, then you are screwed.
However, falling off the stands can be very serious. It puts serious stress on a hull which might not be immediately apparent.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
