Mainsail Reefing - Page 3 - SailNet Community
post #21 of 26 Old 12-06-2007 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Faster's point about making a mounting block for the cam cleat is a very good one.. you want the cam cleat's base to be as flat as possible so the cams don't jam under load.
Thanks, SD. Ronstan make a "curved riser" that sounds like it'll do the job and be heaps easier than making one.
The next trick is to work out how best to fasten it onto the boom, with such thin-walled section. Everything else is rivetted. Self-tappers perhaps??
Shoud I be using plastic or alloy cleats?
Classic30 is offline
post #22 of 26 Old 12-07-2007
If you can rivet the mounting plate/riser and then screw the cam cleat to the mounting plate, that would be ideal. That's how I have attached the line clutches to my mast.
sailingdog is offline
post #23 of 26 Old 12-17-2007 Thread Starter
Classic30's Avatar
Dock
It's been a couple of weeks, but I've almost got my boom re-done - had to change the outhaul setup first to allow for the two reefs, #1 to Starboard and #2 to Port, taking way longer than planned..
I know from an earlier thread that it doesn't make much difference how far aft the turning blocks are, so long as they are well aft of the clew cringle, but is it Standard Practice (tm) to:
(a) Fix the turning blocks on either side of the boom at the same distance along the boom? Or should they be
(b) Staggered (ie. the same distance from the respective cringles)??
post #24 of 26 Old 12-17-2007
I'd stagger them... that way you don't weaken the boom extrusion too much in any given area.
post #25 of 26 Old 12-17-2007
Yes, staggered... for structural reasons as per SD and consistent leech tension with either reef.
Faster is offline
post #26 of 26 Old 12-17-2007 Thread Starter
Classic30's Avatar
Dock
Thanks, guys
Any thoughts on how far back from the cringle the turning blocks should be? 6" or so??
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 08:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 08:00 PM
