Water powered generators - Page 2 - SailNet Community
post #11 of 27 Old 12-17-2007
TThomsen's Avatar
Here is another company that produces a wind/water generator just add the www hamiltonferris.com/water-power.html since I can't post links.
TThomsen is offline
post #12 of 27 Old 12-17-2007
chucklesR's Avatar
What's the point?
Wind gen's don't cost any boat speed, don't get hit by hungry sharks, don't get their cabling snarled up requiring retrieval/redeploying, don't generally get lost by breaking off, work underway and at anchor etc.. and if you got the wind to sail, you've got the wind to make amps.
Okay, some are a bit noisy, but the only silent electrical power generator is solar (my choice, with wind as alternative).
chucklesR is offline
post #13 of 27 Old 12-17-2007
chucklesR's Avatar
AMPAir 100, don't have it installed yet (back yard testing only), seems a little big
post #14 of 27 Old 12-17-2007
Owner, Green Bay Packers
Wind generators are dependant on apparent wind speed and do not generate the amps that towed generators do. Again, if you're riding the hook for the most part, a wind generator may be just the ticket. For those who are planning on spending long periods of time at sea, a towed generator is tough to beat.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #15 of 27 Old 12-17-2007
Chuckles... you're boat is looking a bit on the small side there..
Wind generators are also much noisier than water generators and present more of a danger to crew...
sailingdog is offline
post #16 of 27 Old 12-17-2007
Sasha_V's Avatar
Think of it this way, there are any number of poeple cruising around the world towing thrity meters of ine out the back in case they fall overboard (Last Chance Grab)...This way it also generates power while they pull it around.
Of course, if they ever need to grab hold of it they will discover that it is not just very difficult to hold onto (as per the towed rope) , and even harder to hand over hand back up to the boat (ditto), and vergind ont he impossible to climb vertically up it over the transom and get back on board....But it is all infinitely more amusing when you are being spun around at 450RPM as the prop continues to spin!
Sasha_V is offline
post #17 of 27 Old 12-17-2007
Chucles
Nice moto-sailer! What size electric moter do you have?
RXBOT is offline
post #18 of 27 Old 12-17-2007
Sasha-
That last chance grab rope would actually do quite a bit of good if it was connected to a wind vane/autopilot disconnect, and the boat has a bit of weather helm...so the boat would turn up. Otherwise, you become very tasty shark bait..
post #19 of 27 Old 12-17-2007
baDumbumbum
bobmcgov's Avatar
Cheater Chuckles has a SailFan(tm)! SailFan(tm)! Cheater.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #20 of 27 Old 12-18-2007
chucklesR's Avatar
not my boat - not even a Gemini (tho it looks like one) I found it on the internet. Apparently the wind turbine powers an electric motor.
What's your biggest bonehead move sailing? CharlieCobra Seamanship & Navigation 613 5 Days Ago 08:10 PM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
