12-18-2007
Chuckles can pivot the rotor and use it for vertical takeoff capability.
Originally Posted by Idiens
Not only is the drag of the wind turbine installation reducing your lift-to-drag ratio unfavourably, it's also added top weight, increasing heel and drift when working to windward.
