Old 01-01-2008
rhgraf is on a distinguished road
Using mast as a TV antenna
Has anyone successfuly used your mast or rigging to get a good TV signal? I want to receive digital channels on my boat and recently purchased an indoor amplified antenna that didn't work. My boat is within 25 miles of all of the TV stations so I should be able to get good reception and would rather not have to use a external antenna and run a cable to the boat.
Any suggestions?
Old 01-01-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
I use the rigging on a GRP boat to receive most radio broadcasts, but I don't think it works too well with higher frequencies.
Jonathan-Livingston
Old 01-01-2008
AboardIndigo's Avatar
Seen Your Mamba
AboardIndigo is on a distinguished road
Digital signals are currently broadcast in UHF. I suggest that if you're that close you make a bow-tie in front of mesh antenna of your own that you can put on a stick and rotate as you need to pick up whichever tower you are targeting.
This style has the broadest coverage (as opposed to a yagi), which means you'll have plenty of room for error when it comes to aiming it.
Indigo
1976 Catalina Yachts C-22
Old 01-01-2008
Old Navy
TOMINDC2 is on a distinguished road
HDTV before the mast
Yes, (sort of) . We use the mast to attache a UFO antenna just below our radar antenna. Provides great HDTV reception in ports around the Chesapeake. UFO antennas are inexpensive and they work. Using the mast itself might work, but my guess is that it will require a lot of fiddling to get good reception.
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
