02-17-2008
The problem with an electric outboard on most boats is duration. Most aren't going to have enough running time to make a safe auxiliary engine. Unless you are planning to use it solely for maneuvering the boat in and out of the slip, you'll probably be much better off with a gasoline-powered outboard. Also, on a boat with only an electric outboard, how do you plan on recharging the batteries??? An electric outboard needs some significant battery power, and that means you need some serious re-charging of said batteries most of the time. Unless you only plan on daysailng, the electric outboard becomes a serious logistical problem. Most small boats need more electricity than they can generate, and this is even worse if the boat is powered by an electric outboard, since you can't even run an alternator off of it.
