01-14-2008
Mollusk-
Welcome to sailnet.
It would help if you said what boat you want to do this on. If you have a IP40, then it might make a lot of sense... however, on a Cape Dory 25, it probably is a bad, bad idea.
Dinghies on davits work pretty well when coastal cruising, but on a bluewater passage, the dinghy is very susceptible to getting filled with water and severely damaged. What kind of sailing do you plan to do and what area are you sailing in?
BTW, building your own davits may be more expensive than buying them. Garhauer Marine makes some excellent dinghy davits for a reasonable price.
I'd also recommend you read this post to get the most of your time on Sailnet.
