What would you change?? - Page 2 - SailNet Community
post #11 of 67 Old 01-29-2008
Valiente's Avatar
Originally Posted by Giulietta View Post
Right now I would change my heads from electrical (big mistake) to hand operated, as the ones I have have a bronze body motor with an aluminium motor casing, and are constant driping. (the pump impeler and body are plastic).
Speaking as someone who has fixed your head, I agree. You should get a Lavac head, because it is very reliable and has enough suction to also empty your head bilge. The British don't know much about cooking or electronics, but they sure know toilets.
http://www.lavac.com/pumps.htm
Valiente is offline
post #12 of 67 Old 01-29-2008
Moderator
JohnRPollard's Avatar
Larger holding tank. Have 16 gallons, double that wouldn't be too much.
JohnRPollard is offline
post #13 of 67 Old 01-29-2008
Valiente's Avatar
My ongoing improvements log can be found here for anyone who's interested:
alchemy2009.blogspot.com
I update about once a month. Expect to see a flying diesel in February...
Valiente is offline
post #14 of 67 Old 01-29-2008
jimmyb116's Avatar
New sails its almost as good as a new boat, the old ones diden't look so bad but they had had there day shape wise.
jimmyb116 is offline
post #15 of 67 Old 01-29-2008
Señor Member
TrueBlue's Avatar
This thread is for us to write what things would you change in your boat, and why...
I've made many upgrades and improvements to True Blue, which would take more time than I currently have to list here. I honestly can't think of many more things to change - except perhaps, finding ways to lead all lines back to the cockpit.
But, if I had the supreme power to change anything, it would be to attach a big smile to my wife's face - whenever the boat sailed with a bone in her teeth . . . essentially the reason why she's been sold, within one day at that.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #16 of 67 Old 01-29-2008
That's cause Brits are so full of $***. It makes them an expert on heads and toilets.
sailingdog is offline
post #17 of 67 Old 01-29-2008
On the hard
CharlieCobra's Avatar
New sails, possibly a high cut Yankee jib so I could fly both headsails without them interfering with each other. Electronics for the boat, she only had a depth sounder (which sometimes glitches out) and a knotmeter (inoperable) with a handheld GPS. A tillerpilot would be nice too.
CharlieCobra is offline
post #18 of 67 Old 01-29-2008
jimmyb116's Avatar
Changing from wire halyards to Sampson warp speed, was one of the best for me.
post #19 of 67 Old 01-29-2008
I have one hell of a list. I bought a '91 J40 in November and had all kinds of plans for what I would do over the winter, after I moved the boat from Mystic to my home waters in the Hudson Valley. A week after the closing I took a bad tumble in my house and tore the quad right off my kneecap and broke a bone in my thumb. It was wheelchair>walker >crutches for the last couple of months and goodbye to any work over the winter. Still, that's how I found this forum, to keep from going bananas (not an even trade, but I am of the "if you get a lemon make lemonade" school of thought). I haven't even sailed the boat, other than her survey sea trials, and I certainly haven't lived aboard, but I've been dreaming and scheming over the winter of disability and here are some of the things I'd like to try (after I sail a bit on it, to be sure)
1. Dump the manual heads (there are two, unnecessary on a 40 footer, but that's how it came) The discussion on this forum steered me into doing research on that and I like the idea very much of going AirHead. Getting rid of two space eating 20 gal tanks and lots of smelly hose.
2. Eventually rigging a forestay. The boat currently has running backstays to control mast bend, but they would work very well to counteract a forestay. There is also a waterproof bulkhead near where the tack would be to support the strain at the other end.
3. The big job is in the main cabin. There is a rather silly dinette on the port side, useless when on a heel. I plan to tear that out and put in a pilot berth, a lower settee and convert the existing or make a new fore and aft table. In the footspace of the dinette I would put an extra diesel tank that would increase by about 40% my cruising range under power and make room for a couple of batteries that now are very unhandily placed. Under the pilot berth I plan to put a half a dozen drawers or lockers. Fortunately the interior is the old Herreshof white with wood trim, making it easier to match the existing feel of the boat.
4. There is an anchor well aft that I would change. Tear out the fitted interior for the 25 lb danforth and rebuild a tight locker with an overboard discharge (just like the propane locker) where I would store gasoline for the outboard and for the little Honda generator, as well as said little Honda. I haven't really measured it out yet and I don't think it will fit, but if I can make it big enough to hold the outboard as well, that would be great.
I have many more great ideas, but I really need to sail the boat to see if my ideas are really sensible and worth doing. Sometimes you can outsmart yourself!
At any rate, I am enjoying this forum and working hard to get my working parts back in order so I can DO, rather than dream.
genieskip
Northeast
J40
1991
genieskip is offline
post #20 of 67 Old 01-29-2008
sailortjk1's Avatar
1. Traditional Main with Stak pak (So I wouldn't have to listen to all you people telling me my furling main sucks)
2. You have heard me say this a lot....... An Island Berth for the Captain and First Mate.
3. Larger Holding Tank. We have twenty gallons but it fills up quick, especially when all three girls are on board.
4. Better engine access especially to my in the wrong place facing the wrong way impeller.
Give me some time I will think of more.
Courtney is My Hero
sailortjk1 is offline
Diesel Oil Change Question saurav16 Gear & Maintenance 14 10-15-2007 01:19 PM
Universal 5411 Oil Change saurav16 Gear & Maintenance 10 10-01-2007 08:16 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 08:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 08:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 08:00 PM
