Originally Posted by JohnRPollard
Vega,
Great story. Thanks for sharing and I look forward to hearing more.
A question regarding the problem with your rigging: Your account suggests that you had recently re-rigged your boat prior to setting out. After arrival, Brian Toss apparently inspected the wire and found it "defective". Could you tell us the source, type, etc of the wire and in what way Brian felt it was defective?
I find it disturbing that any new S.S. wire could experience these problems.
We had re-rigged the boat diring our last major re-fit in 1998 so the wire was nine years old at the time of our departure. At the time, the rigger at Ala Wai Marine made a point of showing me the new spool of 316 stainless wire to assure me that I was getting what I was paying (A lot) for. Unfortunately, I did not note the manufacturer in my log.
To clarify: Brion Toss was in Hawaii with his entire crew
rigging the schooner "Sugartime" when we arrived in Port Townsend. We first went to Dan and Lisa at Port Townsend
rigging. Not because I wanted to have them re-
rig the boat, but because I wanted to know the cause of the failure. After I took the mast down, Dan looked at the wire with me. We found broken strands at six points along the headstay and five points along the upper backstay. Later, when his crew returned from Hawaii, one of Brion's riggers asked us for a sample of the wire so I gave him the headstay to take back to their shop where the whole crew examined it very carefully. I am told that as a result, Brion Toss Riggers have changed their procedures and now examine new wire before using it. I gave the backstay to Port Townsend
rigging as they requested for the same reasons. Both
rigging shops told me that it was a bad run of wire and that the failure could not have been foreseen without close examination, under a microscope, of the wire. They also told me that so-called domestic wire rope is made from imported wire strands and that it matters not who the supplier is.
I bought new wire from PT
Rigging and assembled the shrouds and stays with the same Sta-Lok fittings, toggles and
turnbuckles I had used in 1998 after cleaning and polishing and examining with a magnifying glass. After I had the mast back up, the PT
Rigging crew came and checked the tensioning as a courtesy.
Brion Toss is of course the more well known, having written several books on
rigging. But Brion's crew was out of town and, we were hauled out a the PT Boat Haven yard. PT
Rigging is right there and Toss' shop is on the other end of town. Dan and Lisa at PT
Rigging went out of their way to help us even though I merely bought the wire and wedges from them and did all the work myself.
I find I am now allowed to post links so
here is a link to our cruising page. I'm still adding to it but there is plenty there already.
Malie ke kai
