Old 03-02-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
sail 'mileage'
Are there any resources around that give average length of life of a set of sails based on number of miles sailed?
There certainly will be differences for heavy weather offshore vs coastal cruising vs racing and there will be some differences with tropics vs higher lattitudes.
Have any of the sailmakers or any independant sailors published numbers?
Old 03-02-2008
billangiep's Avatar
billangiep is on a distinguished road
My buddy hadn't got far before the spreader tip went through his brand new Jib....maybe 3 or 4 miles? But then I've got who knows how many on my 25 yr. old sails? (g)
Old 03-02-2008
Xort, I really doubt...that is like making tables predicting weather...too many variables
Old 03-02-2008
Xort-
I doubt it. There are so many variables that can reduce the life of a sail.
Did the users let them flog excessively, were they triple stitched at the seams, are they laminate or dacron, did the owners cover them when not in use, were they properly cleaned and maintained, how heavily were they built, etc. UV exposure, sailing in heavier conditions with stronger winds, beating versus running, how much one tacked will also probably affect their lifespan.
Old 03-02-2008
Xort...in case you missed....
I doubt...the variables are too many...like how much wind goes thru...how the owner looked after them, Errol Flyin used them as props etc..
Old 03-02-2008
Then there's the "son cut them up to make a dodger" factor...
Old 03-02-2008
sailhog has a spectacular aura about sailhog has a spectacular aura about
Xort, I really doubt it. There are too many variables. Did the owner let the flog excessively? How the owner looked after them. Did ERrol Flynn use them as props?
Old 03-02-2008
plagerism?
Old 03-02-2008
Don't look at me... One last thought: There's always "did the son cut them up to make a dodger" factor.
Old 03-02-2008
Yes...but in any case, you need to know there is the variable factor...
Like were they used in wind...
Heavy weather sailing sailorfrank Learning to Sail 18 08-24-2009 01:24 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
What is the point of a traveller? dwbecker Learning to Sail 9 09-25-2006 08:35 PM
Sail Care and Cleaning Kathy Barron Gear and Maintenance Articles 0 10-20-2003 08:00 PM
First Sail of the Season Bruce Caldwell Seamanship Articles 0 06-05-2003 08:00 PM
