knots - Page 4 - SailNet Community
post #31 of 58 Old 03-18-2008
John
ImASonOfaSailor's Avatar
Send a message via AIM to ImASonOfaSailor Send a message via MSN to ImASonOfaSailor Send a message via Yahoo to ImASonOfaSailor Send a message via Skype™ to ImASonOfaSailor
I use the Bowline around the house to keep me not forgeting it! What else should I work on? hmmmm... Never heard of frappe
ImASonOfaSailor is offline
post #32 of 58 Old 03-18-2008
The bowline
the round turn and two half-hitches
the cleat hitch
the figure-eight knot or stopper knot
the clove hitch,
the sheet bend,
the rolling hitch,
the reef or square knot
the buntline hitch,
BTW, a Frappe is an ice-cream-based milkshake drink in eastern Massachusetts and Rhode Island. Frapping a coiled line means you're taking turns of line around the coil to prevent it from uncoiling.
P.S. Here's a good page for you to read.
sailingdog is offline
post #33 of 58 Old 03-18-2008
Sailor
Plumper's Avatar
[QUOTE=sailingdog;284559]Frapping a coiled line means you're taking turns of line around the coil to prevent it from uncoiling.
So, not really a knot, just turns around a coil that is then finished off with a hitch......
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Plumper is offline
post #34 of 58 Old 03-18-2008
Sailor
Plumper's Avatar
It has been beaten into me that one is never to finish turning up on a cleat with hitches. It was explained that if the line should come under great load, the hitches make it very difficult to release the line. The right way is to put several full turns around the cleat after having done several figure eights on the cleat. The part that holds the line from slipping is the figure eights where they bind against one another across the top. The turns around put on after are simply to keep it snug.
Thoughts?
Plumper is offline
post #35 of 58 Old 03-18-2008
I believe this is the case on very large ships, but not on a 30' sailboat. The fact that the lines on a tall ship may be unchanged for days or weeks, under fairly high loads, means that undoing a finished hitch may be very difficult. That generally isn't the case with a 30' cruising sailboat. The loads are lower, the amount of time the lines are under load are generally shorter.
Thoughts?
post #36 of 58 Old 03-18-2008
Sailor
Plumper's Avatar
I don't understand why that requires a hitch. Shouldn't that (lesser loads, shorter time) make the hitch unnecessary?
Plumper is offline
post #37 of 58 Old 03-18-2008
Gary M's Avatar
Carrick Bend
It used to be when I joined two lines I would put a bowline in one then tie another onto that loop. I thought that was dumb so I looked up the proper knot which is a Carrick Bend.
It is easy to tie and more important for me easy to remember and can be used to join line of various sizes.
Gary
Gary M is offline
post #38 of 58 Old 03-18-2008
1" lines don't blow around in 30 knots of wind and uncoil from a cleat... 3/8" lines, like those found on a 30' sailboat... do.
post #39 of 58 Old 03-18-2008
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
A fun knot to learn is the "Flying Bowline" - also known as the tugboat bowline. It's actually quite easy, once you've seen it done. It's called the flying bowline because it (more or less) finishes tying itself as you throw it. I can tie the thing - but only for demonstrating purposes. Trying to tie one while heading into a slip , it always collides with something and I just end up embarrassed.
Also, one of the things I've noticed - a lot - is that many people incorrectly tie a cleat hitch. It is important to go to the far side of the cleat first - not the near side. If you go to the near side first, it ends up wedging and jamming as soon as it is put under tension. (This is why so many cleats are placed at an angle to the fairlead. When they're directly in line - I am suspicious of the boat builder or designer - what else doesn't he know?)
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
post #40 of 58 Old 03-18-2008
Northeast 25 O'day Owner
Birdface's Avatar
Originally Posted by Fstbttms View Post
I had a sailing instructor years ago who could tie a bowline one-handed. He held a piece of line with the bitter end dangling, whipped and flipped it around for a second and sure enough, it came out tied in a bowline.
This was probably the flying bowline just described. I could probably get it one handed with practice.
To finish the knot you have to pull the finished/standing side of the line through the loop made with the "flying" side.
I'll go try it for a bit
1976 25' O'day - "SeaWind"
Hello Sailor: "I've just learned that good boats, in good hands, are damned robust creations."
Birdface is offline
Life in the Danger Zone SailNet Racing Articles 0 11-22-2003 08:00 PM
Seven Knots You Can't Live Without Sue & Larry Learning to Sail Articles 0 11-14-1998 08:00 PM
Seven Knots You Can't Live Without Sue & Larry Seamanship Articles 0 11-14-1998 08:00 PM
