Blogs
User Name
Old 03-31-2008
billyg billyg is offline
billyg is on a distinguished road
Keel Bolt Access Well Water
I have a Hunter Passage 42, 1995 model. In the forward keel bolt access well locker (just aft of the forward head, on the centerline of the boat, I have collected water continuously to a depth of approximately 3 inches (but no above the top of the keel nut). The first time I noticed this the water had a pink color indicative of the antifreeze used during winterization. The source of the water appears to be from some location aft of this access well locker approximately two feet below the level of the salon floor. There is a small hole that is lined in fiberglass. The well locker when it "refills" does not go above the depth of approximately three inches. The water is now clear in color. I have not filled any water tanks as of yet.
Do any of you have a schematic showing this well and any connections it may have to other parts of the vessel?
Any idea what the source of this water may be?
Old 04-01-2008
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
The correct marine terminology for this is "a leak".
Perhaps you could grab a flashlight and take a look back there to see where it actually is coming from ???
This is good. It is an indication that the leak is from inside the boat rather than coming through the hull.
This is good - you might want to hold off until you have located and fixed the source of the leak.
No - I am fresh out of them but I think that if you asked some people here:
Hunter Owners.com for owners sailing production sailboats
you might find someone who does.
Any idea what the source of this water may be?[/
Hmm - I'm going to go out on a limb here and suggest a leak .
Good Luck !
Old 04-02-2008
Thanks Sailormann for the information. I am aware the correct terminology for this situation is a "leak" and felt no reason to even state the term. The water access hole is at the very bottom of the keel bolt access well and not accessible to see into even with a flashlight and mirror. I have checked the Hunter Manual and have contacted Hunter to no avail and not even a reply. Thus I came to this forum for other potential sources of information. You have given me information which has given me another idea to investigate however.
Thanks
Old 04-02-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Sailormann-
That was rather tame considering the boat in question is a Hunter....
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
Old 04-02-2008
Here .. Pull this
Thanks
You're welcome Sorry for being a bit sarcastic there but your post was so innocently couched that I couldn't help myself.
Anyway - before you do anything - have you ruled out the possibility that this is a limber hole ??
Limber Holes- Openings through frames to permit water to drain to the lowest part of the bilge.
Old 04-02-2008
Just curious, do you use Pink Antifreeze to winterize the freshwater system or hot water heater? If so, maybe that is the source of the leak.
Old 04-02-2008
Here .. Pull this
Sailormann-
I have resolved not to be too caustic with newbies Sometimes I make myself so proud
Old 04-02-2008
LOL... I'm not so good at that...
Display Modes
vB code is On
Southerly 101 PracticalSailor Buying a Boat Articles 5 02-17-2008 10:33 AM
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 37 11-15-2007 10:26 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 9 01-09-2007 11:39 AM
Watermakers Don Casey Miscellaneous 0 02-01-2004 07:00 PM
Water Ballast/Manufacturer RSJ Buying a Boat 6 03-07-2002 05:59 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
